10.06.2021, 06:31
(10.06.2021, 06:30)admin Wrote: Use this, make sure that all lower/upper limit objects are defined and they all follow the naming scheme as you've posted.
Code:12345678910111213141516171819202122232425$(function() { $('.color-by-value').each(function(_, el) { var addr = $(el).data('object'); if (addr) { grp.listen(addr, function(obj) { var value = obj.value; var name = obj.name; var color = 'green'; var lname = name.replace('ACTUAL_TEMP', 'LOWER_LIMIT'); var uname = name.replace('ACTUAL_TEMP', 'UPPER_LIMIT'); var llimit = grp.getvalue(lname); var ulimit = grp.getvalue(uname); if (value < llimit) { color = 'blue'; } else if (value > ulimit) { color = 'red'; } $(el).css('color', color); }); } }); });
Fantastic!
Will try this out during the day.
