How change objects color at visu
I need change object color at visu depending on values. I use as example 14 type of data. If my value is 100.002 - I want to show it by red color, if 30.05 - green, if zero - blue, etc... Is it possible? Is it possible to do for different objects independently? ( not for all objects 100.002 = red color)..??
Also is possible to change value background such way and show/hide object background (if possible - I want make object flashing such way)
Alex
Please check this post (or whole thread)
https://forum.logicmachine.net/showthrea...08#pid2108
The best option is when you add custom class to this element e.g. "color-by-value" and in Custom Javascript you can then add such code:
const colorByValue = (obj, type) => {
  const {value} = obj;
  const className = "color-by-value";
  const element = document.querySelector(`.${className}`);
  if (value <= 100.002) element.style.color = "red";
  else if (value <= 30.05) element.style.color = "green";
  else if (value === 0) element.style.color = "blue";
grp.listen("1/1/1", colorByValue);
You must change "1/1/1" to this GA which should change a value.
Instead of "<=" you can change to "==" if you really want value to be equal not a threshold.
Instead of element.style.color you can changing classes e.g. ".red", ".green", ".blue".
Done is better than perfect
Big thanks,
will try today to play with such settings.
By the way, is somewhere full documentation of LM internal elements and possibilities for them?
Alex
Since LM uses HTML for visualization the only limit is what browser can do, it's not possible to document this Smile
(18.03.2019, 14:17)admin Wrote: Since LM uses HTML for visualization the only limit is what browser can do, it's not possible to document this Smile
Good to hear, just mean we can do all we want Smile unfortunately  for me I see I just in 1st class at HTML LM school Smile
@buuuudzik
just try your recommendations, something not OK. So some questions appear:
1. For my element at visu I should simply put class name as color-by-value or "color-by-value"???
2. I put this class name to "Additional classes:" of my element, is this right way?
3. At additional classes I used many different scripts, but how divide them? Or just put next one after another??
Below all I have at my custom scripts, I think something not correctly done...:
$(function(){
$('.control-slider').slider().on('update', controlValueChange);
// your code here
$(function(){
if (value >= 0 and value <= 6) element.style.color = "red";
else if (value > 6) element.style.color = "green";
else if (value < 0) element.style.color = "blue";
grp.listen("1/1/0", colorByValue);
$(function(){
var btn = $('.camera'), win = btn.next();
btn.on('vclick', function() {
if (!win.hasClass('hide')) {
win.css({ top: 300, left: 800 });
$(function(){
// Fullscreen function
function fullScreen() {
if (!document.fullscreenElement &&
!document.mozFullScreenElement && !document.webkitFullscreenElement && !document.msFullscreenElement ) {
if (document.documentElement.requestFullscreen) {
document.documentElement.requestFullscreen();
} else if (document.documentElement.msRequestFullscreen) {
document.documentElement.msRequestFullscreen();
} else if (document.documentElement.mozRequestFullScreen) {
document.documentElement.mozRequestFullScreen();
} else if (document.documentElement.webkitRequestFullscreen) {
document.documentElement.webkitRequestFullscreen();
(function() {
var StartUserInput = function (e) {
fullScreen();
// Check if document is loaded in iframe
if (window.frameElement){
// Remove event listeners from parent
var thisparent = window.parent;
thisparent.document.removeEventListener('touchend', StartUserInput);
thisparent.document.removeEventListener('click', StartUserInput);
// Remove events
// Add event listeners to parent
// Event listener for iOS 9+ (is now touchend event)
thisparent.document.addEventListener('touchend', StartUserInput);
thisparent.document.addEventListener('click', StartUserInput);
You've added not appropriate word "and" in condition where in JS you have to use "&&" and there was no ")" at the end of $(function(){});
1. Simple class name withot any other signs.
2. Yes.
3. Every function is in another jQuery wrapper. You can add some comments/title like:
// 1. Coloring value by object________________________________________________
*Use console in browser, and when something strange happen, please console.log(someStrangeVariable) Smile
This is full version in jQuery wrapper:
$(function(){
        if (!element) return console.log(`You must add custom class "${className}" to some element.`);
   if (value >= 0 && value <= 6) element.style.color = "red";
Thank you very much,
now I am more experienced Smile Will correct my errors...
All works perfectly, now I have more possibilities Smile
[quote="buuuudzik" pid="12351" dateline="1552977637"]
2. Yes.
[code]$(function(){
hello buuuudzik
ho to make the color changed depend on the object value itself instead of grp.listen("1/1/0", colorByValue);
regards,
You need grp.listen in any case but you can access the address that is mapped to each element with a certain class like this:
$(function(){
  $('.my_custom_class').each(function(_, el) {
    var addr = $(el).data('object');
    if (addr) {
      log(addr);
(28.01.2021, 09:36)admin Wrote: You need grp.listen in any case but you can access the address that is mapped to each element with a certain class like this:
$(function(){
    if (addr) {
      log(addr);
hello admin
I still beginer in JS
your script will detect the GA
but how to change the color depend on GA's value
What is the object data type?
(28.01.2021, 15:21)admin Wrote: What is the object data type?
Could it be independent on data type?
If not choose floating
Full example, additional class is color-by-value. It changes text color depending on current value but any other CSS property can be changed this way.
$(function() {
  $('.color-by-value').each(function(_, el) {
    if (addr) {
      grp.listen(addr, function(obj) {
        var value = obj.value
          , color = 'blue'; // default color
        if (value >= 0 && value <= 6) {
          color = 'red';
        else if (value > 6) {
          color = 'green';
        $(el).css('color', color);
(29.01.2021, 08:03)admin Wrote: Full example, additional class is color-by-value. It changes text color depending on current value but any other CSS property can be changed this way.
$(function() {
    if (addr) {
          color = 'red';
          color = 'green';
thank you admin.
great job
$(function() {
    if (addr) {
          color = 'red';
          color = 'green';
thank you admin.
great job
Hello, I would like to use this example so that when a specific address is TRUE or FALSE
Like this:
$(function() {
    if (addr) {
        var color;
        if (obj.value) {
          color = 'green';
        else  {
          color = 'red';
