26.08.2022, 14:05
(26.08.2022, 12:55)admin Wrote: You can create a scheduled script that runs every minute and publishes all values. Each message has to specified manually due to a variable format. Add as many addmessage calls as needed and change grp.getvalue addresses. The script will automatically disconnect once all messages are published.
Thank you very much admin. Always a life saverCode:broker = 'mqtt.eniris.be' username = 'xxx' password = 'xxx' port = 1883 messages = {} time = os.time() function addmessage(topic, data) messages[ #messages + 1 ] = { topic = topic, data = require('json').encode(data), } end addmessage('standard1/rp_one_m/waterMetrics/' .. username, { time = time, extraTags = { subId = 'T19', }, fields = { absVolume_m3 = grp.getvalue('1/1/1'), flow_m3ph = grp.getvalue('1/1/2'), } }) addmessage('standard1/rp_one_m/weatherMetrics/' .. username, { time = time, extraTags = { subId = 'T19', }, fields = { outdoorTemperature_degC = grp.getvalue('1/1/3'), outdoorBrightness_lux = grp.getvalue('1/1/4'), windSpeed_kmph = grp.getvalue('1/1/5'), } }) addmessage('standard1/rp_one_m/gasMetrics/' .. username, { time = time, extraTags = { subId = 'T19', }, fields = { absVolume_Nm3 = grp.getvalue('1/1/6'), } }) mqtt = require('mosquitto') client = mqtt.new() mids = {} pubcount = 0 client.ON_CONNECT = function(status, rc, msg) if status then log('mqtt cloud connected') for _, message in ipairs(messages) do local mid = client:publish(message.topic, message.data) if mid then pubcount = pubcount + 1 mids[ mid ] = true end end if pubcount == 0 then client:disconnect() end else log('mqtt cloud connect failed ' .. tostring(msg)) client:disconnect() end end client.ON_PUBLISH = function(mid) if mids[ mid ] then mids[ mid ] = nil pubcount = pubcount - 1 if pubcount == 0 then log('disconnecting') client:disconnect() end end end client:login_set(username, password) status, rc, msg = client:connect(broker, port) if status then client:loop_forever() else log('cloud connect failed: ' .. tostring(msg)) end
