20.01.2017, 08:02
Hello!
I have a spacelynk installed in a commercial office building. There are 574 objects added to the spacelynk, and there are several event-based scripts running with the same script.
The script triggers everytime there's movement in the room or the cooling % changes. There are about 40-50 of these scripts, but they don't occur too often as I've monitored.
But the spacelynk is running with a 85% - 89% load. Is this an issue? We are planning to add visualisation for 3 floors and a few more scripts for energy management, I'm just worried that the spacelynk can't handle it.
Is it the scripts that are causing the memory load or is there something else?
movement = grp.getvalue('0/2/9')
cooling = grp.getvalue('1/2/53')
setSpjeld = '3/2/23'
if movement == true then
grp.write(setSpjeld, cooling)
grp.write(setSpjeld, 0)
