LM phone call to phone number
here is SMS message possibility describe, and latest CSQ (signal level was added):
https://forum.logicmachine.net/showthrea...hlight=CSQ
Can we somehow add ATD modem command (call to number) to modem library?
SMS/Telegram/E-mail is not always take attention when we are busy, but if we can initiate call to showed in script number and enter how many rings can be done - such way can be used for security or fire alarm notification.
Info found about AT commands:
https://m2msupport.net/m2msupport/voice-...oice-call/
I think to user.sms library we need to add something like this - very simple call to number command:
function call(number)
  cmd = string.format('ATD', number)
send(cmd)
  sleep(8)
send('ATH')
but where and how do it correctly with line/answer check I still not experienced to do Sad
Error I have:
User library sms:472: attempt to call global 'send' (a nil value)
stack traceback:
User library sms:472: in function 'call'
Alex
Try this (not tested):
function AT:call(number)   self:send('ATD' .. number .. ';')   os.sleep(8)   self:send('ATH') end
(08.08.2023, 08:01)admin Wrote: Try this (not tested):
Hi, this not working,
If I use in script calling this function:
require('user.sms')
call('3711234567')
I have error
Resident script:3: attempt to call global 'call' (a nil value)
stack traceback:
If I use
require('user.sms')
AT:call('3711234567')
Other error:
User library sms:319: attempt to index field 'port' (a nil value)
stack traceback:
User library sms:319: in function 'send'
User library sms:471: in function 'call'
So something needs to be corrected. If will be time, please look what I need correct in script.
BR, Alex
It should be combined with the SMS script.
Change udphandler function in the resident script like this:
-- check local udp server for messages to send udphandler = function(server)   -- check for local sms to send   local msg = server:receive()   -- got no message   if not msg then     return   end   -- split into number and message   local sep = msg:find(' ')   if not sep then     return   end   local num = msg:sub(1, sep - 1)   local txt = msg:sub(sep + 1)   if txt == 'CALL' then     alert('calling: ' .. num)     modem:call(num)   else     alert('sending sms: ' .. msg)     modem:sendsms(num, txt)   end end
Then try this script (number should probably start with 00):
require('user.sms') sendsms('003711234567', 'CALL')
it works, but at the end of number semicolon ;  should be added at least for my modem (in some descriptions is needed for ATD command in some not shown)
require('user.sms')
sendsms('003711234567;', 'CALL')
Alex
Forgot to add, that one more "end" should be added in udp handler function:
I have such error when tried to add provided script:
Is it possible to check where I need to add it?
Alex
The message says it, If you want us to look drop full script not screenshot.
(21.08.2023, 07:36)Daniel Wrote: The message says it, If you want us to look drop full script not screenshot.
Hi, sorry. My script:
-- init -- -- if not numbers then   require('user.sms')   require('json')   require('socket')   -- allowed numbers, SMS from other numbers will be ignored   numbers = { '371xxxxxxx', '371xxxxxxx' }   -- port number depends on modem model   comport = 'ttyUSB0'   doreset = false -- set to true if USB reset is required before starting any communication   -- if SIM PIN is enabled, uncomment the line below and replace 0000 with SIM PIN   -- pincode = '0000'   -- command parser   parser = function(cmd, sender)     local find, pos, name, mode, offset, value, dvalue, obj, message     cmd = cmd:trim()     mode = cmd:sub(1, 1):upper()     -- invalid request     if mode ~= 'W' and mode ~= 'R' then       return     end     cmd = cmd:sub(3):trim()     -- parse object name/address     find = cmd:sub(1, 1) == '"' and '"' or ' '     offset = find == '"' and 1 or 0     -- pad with space when in read mode     if mode == 'R' and find == ' ' then       cmd = cmd .. ' '     end     -- find object name     pos = cmd:find(find, 1 + offset, true)     -- name end not found, stop     if not pos then       return     end     -- get name part     name = cmd:sub(1 + offset, pos - offset):trim()     if mode == 'W' then       value = cmd:sub(pos + offset):trim()       if #value > 0 then         -- try decoding value         dvalue = json.pdecode(value)         if dvalue ~= nil then           value = dvalue         end         -- send to bus         grp.write(name, value)       end     -- read request     else       obj = grp.find(name)       -- object not known       if not obj then         return       end       -- send read request and wait for an update       obj:read()       os.sleep(1)       -- read new value       value = grp.getvalue(name)       -- got no value       if value == nil then         return       end       -- add object name if specified       if obj.name then         name = string.format('%s (%s)', obj.name, obj.address)       end       message = string.format('Value of %s is %s', name, json.encode(value))       modem:sendsms('+' .. sender, message)     end   end   -- incoming sms handler   readcsq = function()     local res, err, reply = modem:send('AT+CSQ')     local rssi     if reply then       rssi = reply:match('%+CSQ:%s+(%d+),(%d+)')     end     rssi = tonumber(rssi) or 0     if 2 <= rssi and rssi <= 9 then       quality = 'marginal'     elseif 10 <= rssi and rssi <= 14 then       quality = 'ok'     elseif 15 <= rssi and rssi <= 19 then       quality = 'good'     elseif 20 <= rssi and rssi <= 30 then       quality = 'excellent'     else       quality = 'unknown'     end     grp.write('0/0/40', quality)  -- Modem signal level write to group   end   csqtime = os.time()   handler = function(sms)     alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))     -- sms from known number, call parser     if table.contains(numbers, sms.sender) then       parser(sms.data, sms.sender)     end   end   -- check local udp server for messages to send udphandler = function(server)   -- check for local sms to send   local msg = server:receive()   -- got no message   if not msg then     return   end   -- split into number and message   local sep = msg:find(' ')   if not sep then     return   end   local num = msg:sub(1, sep - 1)   local txt = msg:sub(sep + 1)   if txt == 'CALL' then     alert('calling: ' .. num)     modem:call(num)   else     alert('sending sms: ' .. msg)     modem:sendsms(num, txt)   end     end   end -- look like this place could be correct??------------------------------------------------------------------------------- -- handle data from modem if modem then   if modem:run() then     now = os.time()     delta = math.abs(now - csqtime)     if delta >= 15 then       csqtime = now       readcsq()     end     udphandler(server)   else     alert('SMS handler lost connection')     modem:reinit()   end -- modem init else   alert('SMS handler init')   -- open serial port   modem = AT:init('/dev/' .. comport, doreset)   -- init ok   if modem then     -- set sms handler     modem:setsmshandler(handler)     -- enable local echo     modem:send('ATE1')         -- send pin if set     if pincode then       modem:send('AT+CPIN=' .. pincode)       modem:read()     end     -- phase 2+     modem:send('AT+CSMS=1')     -- set to pdu mode     modem:send('AT+CMGF=0')     -- enable sms notifications     modem:send('AT+CNMI=1,1,0,0,1')     -- fixup encoding     modem:send('AT+CSCS="GSM"')     --modem:send('AT+CSCS="UCS2"') --not working     -- modem:send('ATD+371xxxxxxx;')    -- sleep(8)    -- modem:send('ATH')         --modem:send('AT+CSQ')     --modem:read()     -- delete all saved messages     modem:send('AT+CMGD=1')     sleep(0.2)      modem:send('AT+CMGD=2')     sleep(0.2)      modem:send('AT+CMGD=3')     sleep(0.2)      modem:send('AT+CMGD=4')     sleep(0.2)      modem:send('AT+CMGD=5')     sleep(0.2)      modem:send('AT+CMGD=6')     sleep(0.2)      modem:send('AT+CMGD=7')     sleep(0.2)      modem:send('AT+CMGD=8')     sleep(0.2)      modem:send('AT+CMGD=9')     sleep(0.2)      modem:send('AT+CMGD=10')     sleep(0.2)      modem:send('AT+CMGD=11')     sleep(0.2)      modem:send('AT+CMGD=12')     sleep(0.2)      modem:send('AT+CMGD=13')     sleep(0.2)      modem:send('AT+CMGD=14')     sleep(0.2)      modem:send('AT+CMGD=15')     sleep(0.2)      modem:send('AT+CMGD=16')     sleep(0.2)      modem:send('AT+CMGD=17')     sleep(0.2)      modem:send('AT+CMGD=18')     sleep(0.2)      modem:send('AT+CMGD=19')     sleep(0.2)      modem:send('AT+CMGD=20')     -- local udp server for sending sms     server = socket.udp()     server:setsockname('127.0.0.1', 12535)     server:settimeout(0.1)     alert('SMS handler started')   -- init failed   else     alert('SMS USB init failed')   end end
BR, Alex
Drop this script to notepad++, select language LUA and it will highlight you which if belongs to which end.
I have this reactor
LM5 Reactor IO V2/V3 + LTE
And use SIM for send mail and SMS , this works, but if I try to read signal response is nil.
this is my resident script
-- init if not numbers then   require('user.sms')   require('json')   require('socket')   -- allowed numbers, SMS from other numbers will be ignored   numbers = { '3332958126' }   -- port number depends on modem model   comport = 'ttyUSB2'   doreset = false -- set to true if USB reset is required before starting any communication   -- if SIM PIN is enabled, uncomment the line below and replace 0000 with SIM PIN   -- pincode = '0000'   -- command parser   parser = function(cmd, sender)     local find, pos, name, mode, offset, value, dvalue, obj, message     cmd = cmd:trim()     mode = cmd:sub(1, 1):upper()     -- invalid request     if mode ~= 'W' and mode ~= 'R' then       return     end     cmd = cmd:sub(3):trim()     -- parse object name/address     find = cmd:sub(1, 1) == '"' and '"' or ' '     offset = find == '"' and 1 or 0     -- pad with space when in read mode     if mode == 'R' and find == ' ' then       cmd = cmd .. ' '     end     -- find object name     pos = cmd:find(find, 1 + offset, true)     -- name end not found, stop     if not pos then       return     end     -- get name part     name = cmd:sub(1 + offset, pos - offset):trim()     if mode == 'W' then       value = cmd:sub(pos + offset):trim()       if #value > 0 then         -- try decoding value         dvalue = json.pdecode(value)         if dvalue ~= nil then           value = dvalue         end         -- send to bus         grp.write(name, value)       end     -- read request     else       obj = grp.find(name)       -- object not known       if not obj then         return       end       -- send read request and wait for an update       obj:read()       os.sleep(1)       -- read new value       value = grp.getvalue(name)       -- got no value       if value == nil then         return       end       -- add object name if specified       if obj.name then         name = string.format('%s (%s)', obj.name, obj.address)       end       message = string.format('Value of %s is %s', name, json.encode(value))       modem:sendsms('+' .. sender, message)     end   end   -- incoming sms handler     readcsq = function()     local res, err, reply = modem:send('AT+CSQ')     local rssi         --log(res, err, reply)         if reply then       rssi = reply:match('%+CSQ:%s+(%d+),(%d+)')     end         rssi = tonumber(rssi) or 0     if 2 <= rssi and rssi <= 9 then       quality = 'marginal'     elseif 10 <= rssi and rssi <= 14 then       quality = 'ok'     elseif 15 <= rssi and rssi <= 19 then       quality = 'good'     elseif 20 <= rssi and rssi <= 30 then       quality = 'excellent'     else       quality = 'unknown'     end     grp.update('32/0/2', quality)     grp.update('32/0/1', rssi)   end   csqtime = os.time()   handler = function(sms)     --alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))     -- sms from known number, call parser     if table.contains(numbers, sms.sender) then       --parser(sms.data, sms.sender)     end   end   -- check local udp server for messages to send   udphandler = function(server)     -- check for local sms to send     local msg = server:receive()     -- got no message     if not msg then       return     end     -- split into number and message     local sep = msg:find(' ')     if not sep then       return     end     --alert('sending sms: ' .. msg)     modem:sendsms(msg:sub(1, sep - 1), msg:sub(sep + 1))   end end -- handle data from modem if modem then   if modem:run() then     udphandler(server)     now = os.time()     delta = math.abs(now - csqtime)     if delta >= 15 then       csqtime = now       readcsq()     end   else     --alert('SMS handler lost connection')     modem:reinit()   end -- modem init else   --alert('SMS handler init')   -- open serial port   modem = AT:init('/dev/' .. comport, doreset)   -- init ok   if modem then     -- set sms handler     modem:setsmshandler(handler)     -- send pin if set     if pincode then       modem:send('AT+CPIN=' .. pincode)       modem:read()     end     -- set to pdu mode     modem:send('AT+CMGF=0')     -- enable sms notifications     modem:send('AT+CNMI=1,1,0,0,0')     -- fixup encoding     modem:send('AT+CSCS="GSM"')     -- delete all saved messages     modem:send('AT+CMGD=1,4')     -- local udp server for sending sms     server = socket.udp()     server:setsockname('127.0.0.1', 12535)     server:settimeout(0.1)     --alert('SMS handler started')   -- init failed   else     --alert('SMS USB init failed')   end end
where is the problem ?
Thank's
What do you get in logs if you uncomment line 99?
local res, err, reply = modem:send('AT+CSQ') local rssi log(res, err, reply)
(15.07.2026, 10:53)admin Wrote: What do you get in logs if you uncomment line 99?
this is the log
* arg: 1
  * string: AT+CSQ
* arg: 2
  * nil
* arg: 3
  * nil
Have you modified the user library?
See this guide: https://forum.logicmachine.net/showthrea...6#pid28906
(15.07.2026, 11:14)admin Wrote: Have you modified the user library?
Yes the file is modified but the same response
* arg: 1
  * string: AT+CSQ
* arg: 2
  * nil
* arg: 3
  * nil
Have you restarted the SMS script after modifying the user library?
(15.07.2026, 12:18)admin Wrote: Have you restarted the SMS script after modifying the user library?
Yes
Send your backup via PM.
