EnOcean USB 300 stick
#21
Every LM version has same sw so if it work for Todayslife it should work for you.
(24.07.2023, 13:48)Daniel Wrote: Every LM version has same sw so if it work for Todayslife it should work for you.
Thank you Daniel. I didn't see any EnOcean Tab under the Logicmachine page. I think it will appear whenever i connect and enable the USB.
No you must install it manually from additional packages.
(25.07.2023, 15:20)Daniel Wrote: No you must install it manually from additional packages.
Can you link me where i can get the extra package for my SW version  20210521?
Is the genohm-scada-enocean_20230316 package in this page https://dl.openrb.com/lm-23-imx6/pkg/ ?
Yes, make sure you use version for your hardware
imx6
imx28
https://dl.openrb.com/lm-23-mxs/pkg/
(26.07.2023, 17:23)Daniel Wrote: Yes,  make sure you use version for your hardware
imx6
imx28
Done. Installed it. It seems to work but why isn't there any profile for A5-20-01 eep?
Is there any method to make it work?
See this
https://forum.logicmachine.net/showthrea...61#pid4261
(27.07.2023, 14:12)Daniel Wrote: See this
Thanks Daniel, i'll take a look forward.
Hi Daniel, Do you know if this gateway as a limit number of devices working toghether?
Rn, i'm managing around 10 devices with various profiles and it seems to work great. I've done a test in the last two days and i never got an error/alert, with the devices always online and communicating.
Please let me know
There is a limit for 128 sending devices but as always the CPU/Memory is the limit to watch for.
(31.07.2023, 11:38)Daniel Wrote: There is a limit for 128 sending devices but as always the CPU/Memory is the limit to watch for.
Great! Thank you!
