Mosaic2.0 still using it?
hi admin
My Mosaic2.0 cannot be opened.
with LM2IF3F.
The current version is 20170620, and trying to upgrade lm2i-20230607 has no effect.
Installing Mosaic3.0 prompts me with 'Error in/www/apps/data/mosaic30/lua/tpl_head.lp at line 298: unexpected symbol near'='.
Is there any solution?
What is the exact hardware model?
Open the enclosure. If you see a CPU module with a uSD card slot then it can upgraded by replacing the card and following the recovery procedure. If you have hardware with built-in flash then nothing can be done with it - this device is no longer supported, you need to buy new LM.
