Threads: 84
here is SMS message possibility describe, and latest CSQ (signal level was added):
https://forum.logicmachine.net/showthrea...hlight=CSQ
Can we somehow add ATD modem command ( call to number) to modem library?
SMS/Telegram/E-mail is not always take attention when we are busy, but if we can initiate call to showed in script number and enter how many rings can be done - such way can be used for security or fire alarm notification.
Info found about AT commands:
https://m2msupport.net/m2msupport/voice-...oice-call/
I think to user.sms library we need to add something like this - very simple call to number command:
function call(number)
cmd = string.format('ATD', number)
send(cmd)
sleep(8)
send('ATH')
but where and how do it correctly with line/answer check I still not experienced to do
Error I have:
User library sms:472: attempt to call global 'send' (a nil value)
stack traceback:
User library sms:472: in function 'call'
Alex
Threads: 47
Try this (not tested):
Code: function AT:call(number)
self:send('ATD' .. number .. ';')
os.sleep(8)
self:send('ATH')
Threads: 84
(08.08.2023, 08:01)admin Wrote: Try this (not tested):
os.sleep(8)
self:send('ATH')
Hi, this not working,
If I use in script calling this function:
require('user.sms')
call('3711234567')
I have error
Resident script:3: attempt to call global 'call' (a nil value)
stack traceback:
If I use
require('user.sms')
AT:call('3711234567')
Other error:
User library sms:319: attempt to index field 'port' (a nil value)
stack traceback:
User library sms:319: in function 'send'
User library sms:471: in function 'call'
So something needs to be corrected. If will be time, please look what I need correct in script.
BR, Alex
Threads: 47
It should be combined with the SMS script.
Change udphandler function in the resident script like this:
Code: -- check local udp server for messages to send
udphandler = function(server)
-- check for local sms to send
local msg = server:receive()
-- got no message
if not msg then
return
-- split into number and message
local sep = msg:find(' ')
if not sep then
return
local num = msg:sub(1, sep - 1)
local txt = msg:sub(sep + 1)
if txt == 'CALL' then
alert('calling: ' .. num)
modem:call(num)
alert('sending sms: ' .. msg)
modem:sendsms(num, txt)
Then try this script (number should probably start with 00):
Code: require('user.sms')
sendsms('003711234567', 'CALL')
Threads: 84
19.08.2023, 11:04
(This post was last modified: 19.08.2023, 11:46 by AlexLV.)
it works, but at the end of number semicolon ; should be added at least for my modem (in some descriptions is needed for ATD command in some not shown)
require('user.sms')
sendsms('003711234567;', 'CALL')
Alex
Forgot to add, that one more "end" should be added in udp handler function:
I have such error when tried to add provided script:
Is it possible to check where I need to add it?
Alex
Threads: 30
The message says it, If you want us to look drop full script not screenshot.
Threads: 84
(21.08.2023, 07:36)Daniel Wrote: The message says it, If you want us to look drop full script not screenshot.
Hi, sorry. My script:
Code: -- init
if not numbers then
require('user.sms')
require('json')
require('socket')
-- allowed numbers, SMS from other numbers will be ignored
numbers = { '371xxxxxxx', '371xxxxxxx' }
-- port number depends on modem model
comport = 'ttyUSB0'
doreset = false -- set to true if USB reset is required before starting any communication
-- if SIM PIN is enabled, uncomment the line below and replace 0000 with SIM PIN
-- pincode = '0000'
-- command parser
parser = function(cmd, sender)
local find, pos, name, mode, offset, value, dvalue, obj, message
cmd = cmd:trim()
mode = cmd:sub(1, 1):upper()
-- invalid request
if mode ~= 'W' and mode ~= 'R' then
return
cmd = cmd:sub(3):trim()
-- parse object name/address
find = cmd:sub(1, 1) == '"' and '"' or ' '
offset = find == '"' and 1 or 0
-- pad with space when in read mode
if mode == 'R' and find == ' ' then
cmd = cmd .. ' '
-- find object name
pos = cmd:find(find, 1 + offset, true)
-- name end not found, stop
if not pos then
return
-- get name part
name = cmd:sub(1 + offset, pos - offset):trim()
if mode == 'W' then
value = cmd:sub(pos + offset):trim()
if #value > 0 then
-- try decoding value
dvalue = json.pdecode(value)
if dvalue ~= nil then
value = dvalue
-- send to bus
grp.write(name, value)
-- read request
obj = grp.find(name)
-- object not known
if not obj then
return
-- send read request and wait for an update
obj:read()
os.sleep(1)
-- read new value
value = grp.getvalue(name)
-- got no value
if value == nil then
return
-- add object name if specified
if obj.name then
name = string.format('%s (%s)', obj.name, obj.address)
message = string.format('Value of %s is %s', name, json.encode(value))
modem:sendsms('+' .. sender, message)
-- incoming sms handler
readcsq = function()
local res, err, reply = modem:send('AT+CSQ')
local rssi
if reply then
rssi = reply:match('%+CSQ:%s+(%d+),(%d+)')
rssi = tonumber(rssi) or 0
if 2 <= rssi and rssi <= 9 then
quality = 'marginal'
elseif 10 <= rssi and rssi <= 14 then
quality = 'ok'
elseif 15 <= rssi and rssi <= 19 then
quality = 'good'
elseif 20 <= rssi and rssi <= 30 then
quality = 'excellent'
quality = 'unknown'
grp.write('0/0/40', quality) -- Modem signal level write to group
csqtime = os.time()
handler = function(sms)
alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))
-- sms from known number, call parser
if table.contains(numbers, sms.sender) then
parser(sms.data, sms.sender)
-- got no message
if not msg then
return
if not sep then
return
modem:call(num)
end -- look like this place could be correct??-------------------------------------------------------------------------------
-- handle data from modem
if modem then
if modem:run() then
now = os.time()
delta = math.abs(now - csqtime)
if delta >= 15 then
csqtime = now
readcsq()
udphandler(server)
alert('SMS handler lost connection')
modem:reinit()
-- modem init
alert('SMS handler init')
-- open serial port
modem = AT:init('/dev/' .. comport, doreset)
-- init ok
if modem then
-- set sms handler
modem:setsmshandler(handler)
-- enable local echo
modem:send('ATE1')
-- send pin if set
if pincode then
modem:send('AT+CPIN=' .. pincode)
modem:read()
-- phase 2+
modem:send('AT+CSMS=1')
-- set to pdu mode
modem:send('AT+CMGF=0')
-- enable sms notifications
modem:send('AT+CNMI=1,1,0,0,1')
-- fixup encoding
modem:send('AT+CSCS="GSM"')
--modem:send('AT+CSCS="UCS2"') --not working
-- modem:send('ATD+371xxxxxxx;')
-- sleep(8)
-- modem:send('ATH')
--modem:send('AT+CSQ')
--modem:read()
-- delete all saved messages
modem:send('AT+CMGD=1')
sleep(0.2)
modem:send('AT+CMGD=2')
sleep(0.2)
modem:send('AT+CMGD=3')
sleep(0.2)
modem:send('AT+CMGD=4')
sleep(0.2)
modem:send('AT+CMGD=5')
sleep(0.2)
modem:send('AT+CMGD=6')
sleep(0.2)
modem:send('AT+CMGD=7')
sleep(0.2)
modem:send('AT+CMGD=8')
sleep(0.2)
modem:send('AT+CMGD=9')
sleep(0.2)
modem:send('AT+CMGD=10')
sleep(0.2)
modem:send('AT+CMGD=11')
sleep(0.2)
modem:send('AT+CMGD=12')
sleep(0.2)
modem:send('AT+CMGD=13')
sleep(0.2)
modem:send('AT+CMGD=14')
sleep(0.2)
modem:send('AT+CMGD=15')
sleep(0.2)
modem:send('AT+CMGD=16')
sleep(0.2)
modem:send('AT+CMGD=17')
sleep(0.2)
modem:send('AT+CMGD=18')
sleep(0.2)
modem:send('AT+CMGD=19')
sleep(0.2)
modem:send('AT+CMGD=20')
-- local udp server for sending sms
server = socket.udp()
server:setsockname('127.0.0.1', 12535)
server:settimeout(0.1)
alert('SMS handler started')
-- init failed
alert('SMS USB init failed')
BR, Alex
Threads: 30
Drop this script to notepad++, select language LUA and it will highlight you which if belongs to which end.
