lua api
hi please i need your help, i use this lua api code to get json data and save it on csv file but when many user send request i have the lines that get mixed up. please how to fixe it.
require('apps')
require('socket.url')
action = socket.url.unescape( getvar('action') or 'none' )
storagename = socket.url.unescape( getvar('storagename') or 'none')
format = socket.url.unescape( getvar('format') or 'string' )
storagevalue = socket.url.unescape( getvar('value') or '{}')
-- Modification pour gérer le nom de fichier et le répertoire
filename = socket.url.unescape( getvar('storagename') or 'none')
folder = '/home/ftp/Rapport_SatCl/Jour/'
if action == 'storageset' then
  if storagename ~= 'none' then
    if format == 'json' then
      storagevalue = json.decode(storagevalue)
     -- Création et enregistrement du fichier CSV
    if filename ~= 'none' then
      local ip = ngx.var.remote_addr
      local filepath = folder..storagename..".csv"
      local file = io.open(filepath, "a")
      -- Ajout des entêtes de colonnes
    if file:seek('end') == 0 then
        file:write("datetime;agenceName;name;caisse;cheque;gestion_de_compte;autre_service;tres_satisfait;satisfait;un_peu_satifait;pas_satisfait;pas_du_tout_satisfait;pas_du_tout;pas_vraiment;plutot_bien;bien;tres_bien;oui;non;commentaire;telephone\n")
    for i, row in ipairs(storagevalue) do
     file:write( row['datetime'] ..";"..row['agenceName']..";"..row['name']..";" .. row['caisse'] .. ";" .. row['cheque'] .. ";" .. row['gestion_de_compte'] .. ";" ..row['autres_services'] .. ";" .. row['tres_satisfait'] .. ";" .. row['satisfait'] .. ";" .. row['un_peu_satifait'] .. ";" .. row['pas_satisfait'] .. ";" .. row['pas_du_tout_satisfait'] .. ";" ..row['pas_du_tout']..";" ..row['pas_vraiment'] .. ";" .. row['plutot_bien'] .. ";" .. row['bien'] .. ";" .. row['tres_bien'] ..";" .. row['oui'] .. ";" .. row['non'] .. ";" .. row['commentaire'] .. ";" .. row['telephone'] .. "\n")
      file:close()
      print('file saved as: ' .. filepath)
      print('no filename specified')
You can create a scheduled script to write data to CSV and use storage lists for storing temporary entries. This will solve the issue with writing in parallel.
This code adds an entry to the end of the list named mylist. Note that the value can only be a string, but not a Lua table.
key = 'mylist'
value = 'some string value'
storage.exec('rpush', key, value)
This code reads all entries from the list named mylist. All read entries are removed. New entries entries that can be added when the script is already running are not affected.
key = 'mylist'
values = storage.exec('lrange', key, 0, -1)
if type(values) == 'table' then
  for _, value in ipairs(values) do
    -- do something with value
  -- remove read entries from the list
  storage.exec('ltrim', key, #values, -1)
(07.08.2023, 08:22)admin Wrote: You can create a scheduled script to write data to CSV and use storage lists for storing temporary entries. This will solve the issue with writing in parallel.
key = 'mylist'
key = 'mylist'
(05.08.2023, 08:59)mellotron Wrote: hi please i need your help, i use this lua api code to get json data and save it on csv file but when many user send request i have the lines that get mixed up. please how to fixe it.
require('apps')
      file:close()
hi is it possible to use more than one storage lis on wiser??
Use a different storage key name.
(24.08.2023, 08:13)admin Wrote: Use a different storage key name.
ok thanks
