28.08.2023, 14:14
Dears, i am connecting a Trilux light to to the logic machine and when i scan, the LM is unable to find any devices. Anyone an idea?
DALI can't find any devices
28.08.2023, 14:14
28.08.2023, 14:17
Which DALI power supply are using? See if you can control the ballast using broadcast command. Also check that the device is not DALI2.
28.08.2023, 14:27
30.08.2023, 07:41
At this moment CANx-DALI can only receive DALI2 frames from the bus. Full DALI2 support with addressing and control is not fully implemented yet.
30.08.2023, 07:52
(28.08.2023, 14:27)KoBra Wrote:(28.08.2023, 14:17)admin Wrote: Which DALI power supply are using? See if you can control the ballast using broadcast command. Also check that the device is not DALI2. Are you sure there is an integrated DALI psu in the trilux light? I have installed a lot of DALI lights, and I have never seen one with an integrated psu. Measure the voltage of your DALI line just to be sure, it should be between 15 - 22 V DC. |
