strange scheduler problem, scripting
Since last week, without script changes i have a strange problem. My script doesn't run as expected.
First my script is planned at 12:00 but runs at 13:00, why?
script:
12345678910111213
cInterval = 24*60*60 --every 24 hours myobjects = grp.tag('update_chk1') for index, value in ipairs(myobjects) do  diff = (os.time() - value.updatetime)  if (diff >= cInterval or value.data == false) then        if value.data then       log('brandmelder check: '..diff..' >= '..cInterval..' true')     else       log('brandmelder check: '..diff..' >= '..cInterval..' false')    end  end end
And then it generates a line in the log:
log value: brandmelder check: 2194 >= 172800 true
That's not true, because 2194 < 172800 and value.data == true
What do i wrong?
Is it a scheduled script or a script triggered by a scheduler event? Are you sure this is the correct script since 172800 is a number of seconds in two days, not one.
(26.01.2017, 12:49)admin Wrote: Is it a scheduled script or a script triggered by a scheduler event? Are you sure this is the correct script since 172800 is a number of seconds in two days, not one.
Its a scheluded script and that doesn't work. If i execute the code in a normal script it works.
Sorry, yes i changed the interval in the script from 24 to 48 to test something, but i pasted the wrong result Sad
This problem starts this weekend, same time with other problems: redis server down? zwave app crash etc (i contacted support about this problem).
Have you tried rebooting the device? Can you make sure that date/time/timezone settings are correct?
date/time/timezone is correct.
it looks like a reboot solved it.
But i use a reboot only if its really needed, because the zwaveapp is not so happy with reboots.
problem is back, scheduled at 12:00 but executed at 13:00 and a log message.
Can you send remote access details via e-mail or PM?
(27.01.2017, 12:10)admin Wrote: Can you send remote access details via e-mail or PM?
done to support
I think the problem is related to a backup of my system that is running on another LM, but where?
