Zerotier
The old LM firmware is missing the zerotier.ikp file. Does anyone have its installation package? Can you share it? Thank you!
ZeroTier is built into firmware, so simply update yours and it will appear. This only applies to devices with newer CPU (i.MX6). Older hardware does not support ZeroTier.
The latest hardware login requires changing the administrator password, which I don't want to do. It would be even better if I could install it through the "zero tier. ipk" interface in System>packcaes
(25.09.2023, 08:47)rw_echo Wrote: The latest hardware login requires changing the administrator password, which I don't want to do. It would be even better if I could install it through the "zero tier. ipk" interface in System>packcaes
Try to restore another firmware but not the later 2022 nor 2023 cause they force psw update. Try fw. 20210521, this for sure not require password changes.
