API Get help
I'm trying to get some data from an API, I managed to connect to the API and get the result in the log, but I'm having trouble understanding how to add the data to virtual group addresses.
http = require('socket.http') ltn12 = require('ltn12') res, code = http.request({ url = 'https://horsensvej.rokum.ro/api/v1/entries?token=https%3A%2F%2Fhorsensvej.rokum.ro%2F%3Ftoken%3Dknx-2e4b5b25355f26bb', method = 'GET', }) log(res, code)
The result I get in log is:
12345678910111213
* arg: 1   * string: "2023-11-27T21:26:49.676Z"    1701120409676    219    "SingleUp"    "xDrip-LimiTTer" "2023-11-27T21:21:49.215Z"    1701120109215    207    "SingleUp"    "xDrip-LimiTTer" "2023-11-27T21:16:47.774Z"    1701119807774    195    "SingleUp"    "xDrip-LimiTTer" "2023-11-27T21:11:46.145Z"    1701119506145    184    "Flat"    "xDrip-LimiTTer" "2023-11-27T21:06:44.795Z"    1701119204795    183    "Flat"    "xDrip-LimiTTer" "2023-11-27T21:01:43.307Z"    1701118903307    183    "SingleUp"    "xDrip-LimiTTer" "2023-11-27T20:56:42.074Z"    1701118602074    168    "SingleUp"    "xDrip-LimiTTer" "2023-11-27T20:51:40.281Z"    1701118300281    153    "SingleUp"    "xDrip-LimiTTer" "2023-11-27T20:46:38.060Z"    1701117998060    139    "SingleUp"    "xDrip-LimiTTer" "2023-11-27T20:41:37.989Z"    1701117697989    128    "FortyFiveUp"    "xDrip-LimiTTer" * arg: 2   * number: 200
What now? I need to get the data sorted or something?
I would prefer NOT to get the result, but some pointers so I can understand/learn it.
The data looks tab-separated. This code will split the data into separate lines and then each line into separate items.
lines = data:split('\n') for _, line in ipairs(lines) do   items = line:split('\t')   log(items) end
(28.11.2023, 06:56)admin Wrote: The data looks tab-separated. This code will split the data into separate lines and then each line into separate items.
Okay, I have had some time to look at this again, and I admit I need more help.
The code you provided put the data into separate items, that I should be able to put in group addresses with the grp.checkupdate, but I can't get it working!
Post your full script and describe what exactly you want to achieve.
(29.01.2024, 10:58)admin Wrote: Post your full script and describe what exactly you want to achieve.
That is working, and the code you provided:
But whatever I do I get a:
api 29.01.2024 12:55:29 Resident script:9: attempt to index global 'data' (a nil value) stack traceback:
I want to put each segment into its own group address, Date, rawvalue, value, direction and CGM
Try this:
12345678910111213141516171819202122
res, code = require('socket.http').request({ url = 'https://horsensvej.rokum.ro/api/v1/entries?token=https%3A%2F%2Fhorsensvej.rokum.ro%2F%3Ftoken%3Dknx-2e4b5b25355f26bb', method = 'GET', }) if not res then   log('request failed', code)   return end lines = res:split('\n') items = lines[ 1 ]:trim():split('\t') for i, item in ipairs(items) do   items[ i ] = item:gsub('^"(.*)"$', '%1') end grp.checkupdate('1/1/1', items[ 1 ]) grp.checkupdate('1/1/2', items[ 2 ]) grp.checkupdate('1/1/3', items[ 3 ]) grp.checkupdate('1/1/4', items[ 4 ]) grp.checkupdate('1/1/5', items[ 5 ])
(29.01.2024, 12:54)admin Wrote: Try this:
Works like a charm, as always.
How would you go about changing the first item, that I assume is time/date in ISO 8601, to 3 byte time /day?
Use this:
datetime = items[ 1 ] year, month, day, hour, minute, second = datetime:match('(%d+)%-(%d+)%-(%d+)T(%d+):(%d+):(%d+)') date = { year = year, month = month, day = day } time = { hour = hour, minute = minute, second = second } grp.checkupdate('0/0/1', date) grp.checkupdate('0/0/2', time)
