LTE ANTENNA
HI
How much can I extend the antenna in the LTE reactor? What specifications should the cable have?
Thank you
Cable length depends on the cable type. For example RG58 cable length is around 6 meters. Note that a longer cable produces higher signal loss so in the end you might get worse signal by placing the antenna higher but having a longer cable.
