Threads: 103
How much is LM5 sensitive for correct voltage of main power supply?
Can I simply use 30V DC available in KNX cable (white and yellow pair)? Or is it definetely out of the allowed tolerance?
Thank you
Threads: 100
Hi Thomas,
the newest line of LM5 (LM5-Lite, LM5-DW1/PMU/RIO) supports up to 30V DC. Initial LM5 supported up to 24V DC. Please send in PM serial nr. of your device, I will tell exactly then.
Threads: 103
The serial is LM53V14170202
The device is LM5Lp
Threads: 100
30V DC is fine in this case.
Threads: 103
Thank you it works
Threads: 2
Same question ... does my LM supports 30V?
- Serial: LM5M3V15A01705027
- Type: LM5p-RD
Thanks in advance.
Threads: 100
all LM5-type devices are based on LM5L as main-board + specific extension is added.
So, yes, LM5p-RD also supports 30V DC powering.
