Threads: 28
27.11.2023, 21:45
(This post was last modified: 28.11.2023, 15:47 by Novodk .)
I'm trying to get some data from an API, I managed to connect to the API and get the result in the log, but I'm having trouble understanding how to add the data to virtual group addresses.
http =
require (
'socket.http' )
ltn12 =
require (
'ltn12' )
res ,
code =
http.request ({
url =
'https://horsensvej.rokum.ro/api/v1/entries?token=https%3A%2F%2Fhorsensvej.rokum.ro%2F%3Ftoken%3Dknx-2e4b5b25355f26bb' ,
method =
'GET' ,
log (
res ,
code )
The result I get in log is:
1 2 3 4 5 6 7 8 9 10 11 12 13
arg :
string :
"2023-11-27T21:26:49.676Z" 1701120409676 219 "SingleUp" "xDrip-LimiTTer"
"2023-11-27T21:21:49.215Z" 1701120109215 207 "SingleUp" "xDrip-LimiTTer"
"2023-11-27T21:16:47.774Z" 1701119807774 195 "SingleUp" "xDrip-LimiTTer"
"2023-11-27T21:11:46.145Z" 1701119506145 184 "Flat" "xDrip-LimiTTer"
"2023-11-27T21:06:44.795Z" 1701119204795 183 "Flat" "xDrip-LimiTTer"
"2023-11-27T21:01:43.307Z" 1701118903307 183 "SingleUp" "xDrip-LimiTTer"
"2023-11-27T20:56:42.074Z" 1701118602074 168 "SingleUp" "xDrip-LimiTTer"
"2023-11-27T20:51:40.281Z" 1701118300281 153 "SingleUp" "xDrip-LimiTTer"
"2023-11-27T20:46:38.060Z" 1701117998060 139 "SingleUp" "xDrip-LimiTTer"
"2023-11-27T20:41:37.989Z" 1701117697989 128 "FortyFiveUp" "xDrip-LimiTTer"
arg :
number :
200
What now? I need to get the data sorted or something?
I would prefer NOT to get the result, but some pointers so I can understand/learn it.
Threads: 43
The data looks tab-separated. This code will split the data into separate lines and then each line into separate items.
lines =
data :
split (
'\n' )
for _ ,
line in ipairs (
lines )
do
items =
line :
split (
'\t' )
log (
items )
Threads: 28
(28.11.2023, 06:56) admin Wrote: The data looks tab-separated. This code will split the data into separate lines and then each line into separate items.
lines =
data :
split (
'\n' )
for _ ,
line in ipairs (
lines )
do
items =
line :
split (
'\t' )
log (
items )
Okay, I have had some time to look at this again, and I admit I need more help.
The code you provided put the data into separate items, that I should be able to put in group addresses with the grp.checkupdate, but I can't get it working!
Threads: 43
Post your full script and describe what exactly you want to achieve.
Threads: 28
(29.01.2024, 10:58) admin Wrote: Post your full script and describe what exactly you want to achieve.
http =
require (
'socket.http' )
ltn12 =
require (
'ltn12' )
res ,
code =
http.request ({
url =
method =
'GET' ,
log (
res ,
code )
That is working, and the code you provided:
lines =
data :
split (
'\n' )
for _ ,
line in ipairs (
lines )
do
items =
line :
split (
'\t' )
log (
items )
end But whatever I do I get a:
api 29.01.2024 12 :
55 :
29
Resident script :
9 :
attempt to index global 'data' (
a nil value )
stack traceback :
I want to put each segment into its own group address, Date, rawvalue, value, direction and CGM
Threads: 43
Try this:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
res ,
code =
require (
'socket.http' ).
request ({
url =
method =
'GET' ,
if not res then
log (
'request failed' ,
code )
return
lines =
res :
split (
'\n' )
items =
lines [
1 ]:
trim ():
split (
'\t' )
for i ,
item in ipairs (
items )
do
items [
i ] =
item :
gsub (
'%1' )
grp.checkupdate (
'1/1/1' ,
items [
1 ])
grp.checkupdate (
'1/1/2' ,
items [
2 ])
grp.checkupdate (
'1/1/3' ,
items [
3 ])
grp.checkupdate (
'1/1/4' ,
items [
4 ])
grp.checkupdate (
'1/1/5' ,
items [
5 ])
Threads: 28
(29.01.2024, 12:54) admin Wrote: Try this:
res ,
code =
require (
'socket.http' ).
request ({
url =
method =
'GET' ,
if not res then
log (
'request failed' ,
code )
return
lines =
res :
split (
'\n' )
items =
lines [
1 ]:
trim ():
split (
'\t' )
for i ,
item in ipairs (
items )
do
items [
i ] =
item :
gsub (
'%1' )
grp.checkupdate (
'1/1/1' ,
items [
1 ])
grp.checkupdate (
'1/1/2' ,
items [
2 ])
grp.checkupdate (
'1/1/3' ,
items [
3 ])
grp.checkupdate (
'1/1/4' ,
items [
4 ])
grp.checkupdate (
'1/1/5' ,
items [
5 ])
Works like a charm, as always.
How would you go about changing the first item, that I assume is time/date in ISO 8601, to 3 byte time /day?
Threads: 43
Use this:
datetime =
items [
1 ]
year ,
month ,
day ,
hour ,
minute ,
second =
datetime :
match (
'(%d+)%-(%d+)%-(%d+)T(%d+):(%d+):(%d+)' )
date = {
year =
year ,
month =
month ,
day =
day }
time = {
hour =
hour ,
minute =
minute ,
second =
second }
grp.checkupdate (
'0/0/1' ,
date )
grp.checkupdate (
'0/0/2' ,
time )
