(06.02.2024, 10:23)admin Wrote: Install System load app and see what process is consuming all CPU.
we did and found that this part using almost 100% of the CPU
1148 avahi-daemon: running [LogicMachine.local]
(06.02.2024, 10:31)Daniel Wrote: Disable KNX IP and see if this helps.
this not worked
System load
PID Process CPU MEM
1 /sbin/init 0.00% 0.61MB
714 /sbin/syslogd-C16 0.00% 0.65MB
716 /sbin/klogd 0.00% 0.62MB
718 /sbin/hotplug2--override --persistent --set-rules-file /etc/hotplug2.rules --set-coldplug-cmd /sbin/udevtrigger --max-children 1 0.00% 0.66MB
912 /sbin/watchdog-t 5 /dev/watchdog 0.00% 0.59MB
979 /usr/sbin/gpiod-l /lib/restore/defaults.sh -d /lib/restore/restore.sh -b 9 0.00% 0.30MB
990 dropbear-R -p 22 -K 300 0.00% 0.60MB
994 /usr/sbin/ntpd-n -p 0.europe.pool.ntp.org -p 1.europe.pool.ntp.org -p 2.europe.pool.ntp.org -p 3.europe.pool.ntp.org 0.00% 0.67MB
1003 /usr/sbin/redis-server/etc/redis.conf 0.00% 1.18MB
1064 lua/lib/genohm-scada/core/groupmonitor.lua 0.00% 1.88MB
1074 lua/lib/genohm-scada/core/scenes.lua 0.00% 1.86MB
1075 lua/lib/genohm-scada/core/ipblocker.lua 0.00% 0.93MB
1077 /usr/bin/eibd-e 1.1.1 -q 100 -F n,n,n,n,0,0 tpuarts:/dev/ttymxc5 0.00% 1.03MB
1081 lua/lib/genohm-scada/plugins/modbus/daemon.lua 0 0.00% 1.96MB
1092 lua/lib/apps/daemon.lua canx /home/apps/store/daemon/canx/daemon.lua 0.00% 1.99MB
1094 lua/lib/apps/daemon.lua lmcloud /home/apps/store/daemon/lmcloud/daemon.lua 0.00% 2.13MB
1114 nginx:master process nginx -c /tmp/nginx.conf 0.00% 1.07MB
1116 nginx:worker process 0.70% 3.74MB
1122 /usr/sbin/crond-l 20 -c /etc/crontabs 0.00% 0.60MB
1128 /usr/bin/dbus-daemon--system 0.00% 0.78MB
1147 avahi-daemon:running [LogicMachine.local] 96.84% 1.07MB
1161 /usr/sbin/zerotier-one-p9993 /var/lib/zerotier-one_default 0.18% 5.88MB
1172 avahi-browse-l _http._tcp 0.00% 0.81MB
system 0.35%
total 98.07% 31.59MB
