Here my first version
https://github.com/apption-labs/meater-cloud-public-rest-api
Rate limit:
Recommended: 2 requests per 60 seconds.
Maximum: 60 requests per 60 seconds.
There may be a delay between the MEATER Cloud seeing your device and it being returned in this endpoint.
- Device must be seen by the MEATER Cloud. Ensure you've completed a cook while connected to MEATER Cloud.
- The MEATER app or Block must have an active Bluetooth connection with the device.
- The MEATER app or Block must have an active MEATER Cloud connection.
https = require('ssl.https')
json = require('json')
ltn12 = require('ltn12')
iDebug = false
cloudUrl = 'https://public-api.cloud.meater.com/v1'
cloudEmail = 'myemail@address.nl'
cloudPwd = 'mypassword'
-- get token
function getToken()
  tbl = {}
  local iData = {}
  iData['email'] =  cloudEmail
    iData['password'] =  cloudPwd
    local iData = json.encode(iData)
  res, code = https.request({
    url = cloudUrl..'/login',
    method = 'POST',
    headers = {
      ['content-type']  = 'application/json',
      ['content-length'] = #iData,
    source = ltn12.source.string(iData),
    sink = ltn12.sink.table(tbl),
  if iDebug then log(res, code) end
  if res and code == 200 then
    resp = table.concat(tbl)
    resp = json.pdecode(resp)
    return resp.data.token
-- get device(s)
function getData(iEndpoint)
  vToken = getToken()
  if vToken then
      url = cloudUrl..iEndpoint,
      method = 'GET',
      headers = {
        ['authorization'] = 'Bearer ' .. vToken
      return res
        log(res,code)
log(getData('/devices'))
--getData('/devices/DEVICEID')
