31.12.2023, 21:13
Hi. I have LSS100100 Wiser for KNX (i.MX6). I want to install HomeKit App this device, but it's not available in the application store. Could you share the .ipk and certificate file?
Wiser for KNX HomeKit App
31.12.2023, 21:13
02.01.2024, 08:36
SE is evaluating this app and it is SE decision to release it or not. We cannot generate certificate for SE apps.
03.01.2024, 20:09
(This post was last modified: 03.01.2024, 20:10 by berhankanbur.)
Can't I install LogicMachine firmware on this device? Or is there another way to run HomeKit?
04.01.2024, 06:41
05.01.2024, 10:30
(02.01.2024, 08:36)Daniel Wrote: SE is evaluating this app and it is SE decision to release it or not. We cannot generate certificate for SE apps. (04.01.2024, 06:41)alexll Wrote:As far as I understand, I will flash the SD Card inside the hardware with the help of a program such as balenaEtcher. So where can I download the firmware file? Also can I go back to the old firmware afterwards?(03.01.2024, 20:09)berhankanbur Wrote: Can't I install LogicMachine firmware on this device? Or is there another way to run HomeKit?
05.01.2024, 10:37
Homekit app will not run on w4k firmware.
05.01.2024, 10:37
(05.01.2024, 10:30)berhankanbur Wrote:(02.01.2024, 08:36)Daniel Wrote: SE is evaluating this app and it is SE decision to release it or not. We cannot generate certificate for SE apps. Follow the official manual to recover the SD. And yes, you can go back with the same method but with the SE firmware.
06.01.2024, 08:06
06.01.2024, 08:30
Only iMX6 CPU is supported.
06.01.2024, 08:49
08.01.2024, 08:30
The only way to update hardware is by buying new LM
19.03.2024, 04:32
19.03.2024, 08:58
It would be more fair to do the comparison with SL as W4K has some limitations on bacnet, users and modbus. Apart of this, everything related to cloud is totally different. We use zerotier for remote access which is a big difference as no solution on SE side for it yet. We also have few extra apps. Aside of the sw LM has many more hardware versions to choose from for different applications. Thanks to this we have more RS485 ports, DALI, canX, 1-wire and many i/Os
19.03.2024, 22:33
Quote:It would be more fair to do the comparison with SL as W4K has some limitations on bacnet, users and modbus. Apart of this, everything related to cloud is totally different. We use zerotier for remote access which is a big difference as no solution on SE side for it yet. We also have few extra apps. Aside of the sw LM has many more hardware versions to choose from for different applications. Thanks to this we have more RS485 ports, DALI, canX, 1-wire and many i/Os Thanks for that a LM it is
21.03.2024, 14:13
everything will work except RS485 ports.
Hi! Is this the same for LSS100200? If install LM software, RS-485 will not work?
21.03.2024, 14:16
There is no difference between SL and W4K in hardware point of view. The ports names are different in SL as LM has two.
21.03.2024, 23:57
(19.03.2024, 22:33)lcrowhurst Wrote:Quote:It would be more fair to do the comparison with SL as W4K has some limitations on bacnet, users and modbus. Apart of this, everything related to cloud is totally different. We use zerotier for remote access which is a big difference as no solution on SE side for it yet. We also have few extra apps. Aside of the sw LM has many more hardware versions to choose from for different applications. Thanks to this we have more RS485 ports, DALI, canX, 1-wire and many i/Os Finally purchased an LM5 , its great, now to get my UI generating script running on it |
