Modbus write multiple registers
Hello!
fw 20160927
Modbus
if not mb then     mbproxy = require('mbproxy')     mb = mbproxy.new() end mb:setslave(4) res, err = mb:writemultipleregisters(46165, o1, o2, o3) if err then log(err); end
Quote:Logs: *string: Illegal function
What not so?
This is a reply from the slave telling that this function is not supported. Actually, writemultipleregisters only make sense when writing one register to a device which only supports function code 16. With multiple registers writemultipleregisters and writeregisters are identical. Try using writeregisters and write only one register at a time.
In a manual on the device it is written what can be written in this address only through function 16.
I tried writeregisters - too an error: Illegal data!
p.s.
this device - http://bolid.ru/files/373/566/s2_pp_v124...only_e.pdf
Do you have jumper XP1 set to master mode?
Writing to multiple register starting at 46165 is only possible when device is master according to manual.
