FTPS trouble with ftp.put
Dear all,
on the advice of the Italian distributor I open this new thread on a topic already partially covered.
I have two LM5 Lite (fw 20240219) on my desktop connected to the same switch, on the first LM I run the client code (scripting/scheduled) you see below and I use the second as an FTP server.
With the FTP server without encryption mode, I remove the two parameters secure = true and datasecure = true from the client code and I can transfer a 2 MB .csv file without problems from the first LM to the other.
If I enable Require Encryption FTPS mode on the server and re-enable the two parameters secure/datasecure on the first LM, I can only transfer small size file (< 8 KB) otherwise I receive a 426 Failure reading network stream error and the file is truncated on the server.
If I use a generic FTPS client like Filezilla or WinSCP I can transfer files of any size on the second LM without error.
Over the weekend I tried to understand more but all I got was a headache...
123456789101112131415161718192021
ftp = require('socket.ftp') ltn12 = require('ltn12') host = 'xxx.xxx.xxx.xxx' user = 'xxx' pass = 'xxx' data = io.readfile('/data/ftp/testfile.txt'path = ('/testfile.txt') res, err = ftp.put({   host = host,   user = user,   password = pass,   argument = path,   type = "a",   secure = true, -- Remove with FTP Server without encryption   datasecure = true, -- Remove with FTP Server without encryption   source = ltn12.source.string(data) })   if not res then   alert('FTP upload error: %s', tostring(err)) end
Install updated package through System config > System > Packages > Add package and see if it helps:
https://dl.openrb.com/pkg/luasocket_2.0....5_imx6.ipk
https://dl.openrb.com/pkg/luasocket_2.0....5_imx6.sig
(25.03.2024, 10:57)admin Wrote: Install updated package through System config > System > Packages > Add package and see if it helps:
From the first tests it seems to work well, thank you for solving this problem so quickly!
Marcello
