Error in LM App Android/IOs
I have an issue with the LM app, when I try to open mosaic thorugh cloud.
there is a spinner that never stops, and after a few minutes logs out.
Here is a Video showing the issue.
https://drive.google.com/file/d/1Ws0E2u4...sp=sharing
(04.04.2024, 16:49)Morpheus09 Wrote: I have an issue with the LM app, when I try to open mosaic thorugh cloud.
Which is it your firmware? If you are running the 2024.02, try with LM Home
Br Cristian
The spinner is a refresh when websocket connection is not established. Check if you see the same via normal browser.
https://remote.logicmachine.net/user
PS there is new app LM Home
https://forum.logicmachine.net/showthread.php?tid=5220
I updated the Firmware to 2024.02, and now works fine.
With both apps.
(04.04.2024, 17:07)CristianAgata Wrote: Hi,
Br Cristian
The issue did not happen on a browser. only on the app.
(04.04.2024, 17:10)Daniel Wrote: The spinner is a refresh when websocket connection is not established. Check if you see the same via normal browser.
What firmware do you use? Is the LM cloud app up to date? What about Mosaic? What is the device you are testing on?
