socket.smtp error
Does anyone know why I'm gettiging this error when loading this library?
require('socket.smtp')
error loading module 'ssl.core' from file 'Library ssl.so': Error relocating /usr/lib/libcrypto.so.1.1: unsupported relocation type 53 stack traceback: [C]: at 0x000554bc [C]: in function 'require' Library ssl: in function <Library ssl:0> [C]: in function 'require' Library socket/tp: in function <Library socket/tp:0> [C]: in function 'require' Library socket/smtp: in function <Library socket/smtp:0> [C]: in function 'require'
It had been working...
Which firmware version? Might be a sign of SD card being corrupted.
(09.05.2024, 10:44)admin Wrote: Which firmware version? Might be a sign of SD card being corrupted.
20230607
Should I replace SD Card or can I do something else?
You can try reinstalling the firmware but a safer solution is to replace the SD card.
(10.05.2024, 06:44)admin Wrote: You can try reinstalling the firmware but a safer solution is to replace the SD card.
Ok thanks!
