Hi im using an example of Copas and wanted to add some additonal features:
1. Status of connection to object
- i guess i can just write to an object at line " alert('[tcp-client] connection ok') " and line " alert('[tcp-client] connection failed (conn): ' .. err) "
2. Object to control TCP connect, reconnect and disconnect
- Aside from just disabling and enabling the script is there a method to call functions for connect, reconnect and disconnect from an object while the script is running?
3. Detection of loss of TCP connection and attempt to reconnect
- i tried adding a kep alive function that sends a string 'ping' and try to check if it fails to send, however this does not work. I disconnect the ethernet to the end device and the 'ping' message keeps sending and copas/ tcp does not fail or recognise the end device is no longer connected?
if not ready then
socket = require("socket")
copas = require("copas")
alert('not Ready')
ready = true
function parse(data)
alert('parsing: ' .. data)
function fromKNX(command)
alert('from KNX.. ' .. command)
local server = socket.udp()
server:setsockname("127.0.0.1", 23456)
function handler(skts)
skts = copas.wrap(skts)
alert("UDP connection handler")
while true do
local s, err
alert("UDP receiving...")
s, err = skts:receive(2048)
if not s then
alert("UDP Receive error: " .. err)
break
alert("Received data, bytes: " .. s)
fromKNX(s)
copas.addserver(server, handler, 1)
-- Define the init function
function init()
alert('Initialization function called')
-- Add some initialization code here
function connect_tcp()
alert('Attempting to connect to TCP server')
local skt, err = socket.connect('x.x.x.x’, xxxx)
if skt then
skt:settimeout(0)
copas.addthread(function()
while true do
local resp, err = copas.receive(skt, '*l')
if not resp then
alert("Receive error: " .. err)
copas.removeserver(skt)
skt = nil
break
parse(resp)
-- Attempt to reconnect after disconnect
connect_tcp()
end)
-- Keep-alive mechanism: send ping every 5 seconds
while skt do
local success, err = skt:send("ping\n")
if not success then
alert("Ping send error: " .. err)
skt:close()
skt = nil
break
copas.sleep(5)
-- Attempt to reconnect after ping failure
connect_tcp()
end)
warningfailed = true
init()
if warningfailed then
warningfailed = false
-- Retry connection after a delay
copas.sleep(5) -- Wait for 5 seconds before retrying
connect_tcp()
end)
if not skt then
alert('not socket')
connect_tcp()
copas.loop()
tart_server()
