Connector Bridge RS485 Interface
Hello, I have a Connector Bridge RS485 Interface device. Can you send the script how to send such commands through modbus.
I am trying the common function:
function blind(command)
require('serial')
port = serial.open('/dev/RS485-1', { baudrate = 9600, parity = 'none', databits = 8, stopbits = 1 })
port:flush()
port:write(command)
port:close()
Example event script:
blind('!000V?;')
I am attaching the command of the device
Thank you
.pdf   Connector_Bridge_RS485_Interface.pdf (Size: 288.66 KB / Downloads: 17)
Use this script to send a command and receive a reply from the bridge. Make sure that only a single script instance is running at any time. Serial port cannot be shared between multiple concurrent scripts.
require('serial')
port = serial.open('/dev/RS485-1', { baudrate = 9600 })
function readreply()
  local line = {}
  while true do
    local char, err = port:read(1, 5)
    if char == nil then
      return nil, err
    elseif char == ';' then
      break
      line[ #line + 1 ] = char
  return table.concat(line)
command = '!000V?;'
port:write(command)
res, err = readreply()
log(res, err)
