[RELEASE] LogicMachine firmware 2024.04
#21
(10.06.2024, 07:02)admin Wrote: @Sral1987, it will be published later this month
@manospsyx, basic auth still works but you have to explicitly send the header. We'll see if something can be implemented just for the Remote services but I cannot promise anything at the moment.
Makes sense! Since a workaround doesn't exist, I'll go ahead and update all integration code to send the header explicitly. Will be a little tedious, but doable. Thank you!
@Sral1987, FW for old devices has been published
I have a somewhat stupid question regarding the import of neighbors. In Firmware 20240426 the import for neighbors is greyed out. Remote Services are enabled.
What am I missing?
And is it correct that I can't transmit Virtual Objects via Remote to another LM?
Thanks for your Help
All devices must have 2024 fw.
I'm just testing wireguard vpn, no success. I guest I should give a local address in format x.x.x.x/24, at least remote interface allowed ip in format x.x.x.x/32 and server address as x.x.x.x:port
It seems to be functional but i'm not able to ping nether way. Maybe there is something wrong in my ip mask.
Another problem: ip must be an static ip but it should be any url so we can resolve a dinamic server, an usual config.
Since we can not get this to work, it is a great addition to vpn connections. Thank you!
@jlfneir, try this updated package. Install through System config > System > Packages > Add Package.
https://dl.openrb.com/pkg/wireguard-lm_2...8_imx6.ipk
https://dl.openrb.com/pkg/wireguard-lm_2...8_imx6.sig
Local address should be /32 since it's the tunnel interface IP address. Allowed address netmask can be different: /32 for single IP access only, /24 for the whole class C network. On the server side the Allowed address value should be the same as the client's Local address (/32).
Hello, after updating an old LM Reactor v3 from 2017 to 2024 firmware, I noticed that the "Objects" tab doesn't display properly (connecting to the LogicMachine in HTTP). Inside the Chrome dev tools, I can see the following error message:
Quote:WebSocket connection to 'ws://xxxx/scada-main/objects/ws-main' failed:
start @ 10-objects.js.gz?version=20240426:1
(anonymous) @ 10-objects.js.gz?version=20240426:1
I retried connecting to the LM in HTTPS, and this time, the Objects tab was displayed properly, and the error above didn't show up anymore.
It seems to be specific to some version upgrades, because for instance if I upgrade a brand-new LM from 2023 to 2024 firmware, the same problem won't occur connecting in plain HTTP. It seems to only happen if you update from a really old firmware to the 2024 one.
Do you have any workaround?
Make a backup, then use the recovery image to reflash SD with latest fw and restore backup. You can send us the backup via PM to check.
