Threads: 35
You will need to write to virtual object and convert values and then write to your control mode.
Threads: 48
You can also use a custom widget where you can map a numeric value to text for mode selection.
Threads: 10
23.01.2024, 14:01
(This post was last modified: 23.01.2024, 14:18 by Ranjeet.)
for Air Conditioner Swing Control which Widget Do we have to choose in Mosiac App
Threads: 35
Try and check what works for you or make a custom one in widget creator.
Threads: 39
hi,
on wiser 4knx ios app, how you deal with changeover on dpt20 group adress ? I only found for 1 bit changeover object.
Only solution script ?
regards
SE ECO EXPERT
Threads: 35
Script
Threads: 39
(18.06.2024, 06:32)Daniel Wrote: Script
ok thanks
SE ECO EXPERT
