21.06.2024, 05:54
Hello, I was wondering how many KNX IP tunneling connections in parallel the LM can handle?
KNX IP Parallel connections
21.06.2024, 05:54
21.06.2024, 06:59
There is no limit but the hardware has some limits, some years ago I tested 6 and worked fine.
21.06.2024, 07:25
25.06.2025, 11:44
(This post was last modified: 25.06.2025, 11:47 by manos@dynamitec.)
Hello Daniel, admin,
Can LM5Lp2 support more than one KNX IP Tunneling connections at the same time? If yes, is there any way to set a unique KNX physical address for each tunnel? Kind Regards, Manos
25.06.2025, 11:48
LM supports multiple tunneling connections but the address always will be the same.
25.06.2025, 11:50
25.06.2025, 11:51
You are still connecting to the same device so address should be the same.
Ctrl+F5 |
