W4K - Touch 4 - Widget text colour
Hello, guys!
I couldn`t find a way to change the colour of the text that I`m showing in the picture. Please let me know if there is a way! Thank you so much!!
Is this just text element on custom widget or what? Text element has font color but Touch is not the same app as Mosaic.
Under Touch Config -> Configuration Wheel -> Styles you can add this into the custom CSS to change the color(s)
.se-button-multi-title-light-switch.se-button-multi-title-1 {     color: red; } .se-button-multi-title-light-switch.se-button-multi-title-2 {     color: blue; } .se-button-multi-title-light-switch.se-button-multi-title-3 {     color: green; } .se-button-multi-title-light-switch.se-button-multi-title-4 {     color: yellow; } .se-button-multi-title-light-switch.se-button-multi-title-5 {     color: orange; } .se-button-multi-title-light-switch.se-button-multi-title-6 {     color: pink; }
(22.07.2024, 09:03)Erwin van der Zwart Wrote: Under Touch Config -> Configuration Wheel -> Styles you can add this into the custom CSS to change the color(s)
Thank you, solved my problem!
