Modbus sent single value bit
Hello, maybe you can help me, how can I send the value only to 8bit, because if I use this script everything works, but it also activates 1bit as an example.
I want to send the value only as an example 8bit
require('luamodbus')
mb = luamodbus.tcp()
mb:open('10.30.0.242', 8000)
mb:connect()
mbConfusedetslave(1)
bendra_reiksme = mb:readregisters(1000)
function setbit(value, bitnr)
  local mask = bit.lshift(1, bitnr)
  return bit.bor(value, mask)
value = setbit(1, 8)
mb:writeregisters(1000, value)
mb:close()
Try this:
123456789101112131415161718
require('luamodbus') mb = luamodbus.tcp() mb:open('10.30.0.242', 8000) mb:connect() mb:setslave(1) value = mb:readregisters(1000) function setbit(value, bitnr)   local mask = bit.lshift(1, bitnr)   return bit.bor(value, mask) end value = setbit(value, 8) mb:writeregisters(1000, value) mb:close()
The recommended approach is to use profiles.
This script is the same as mine. How can I send a value of only 8bit, because now 1bit is momentary, and when I send a value of 8bit, it also activates 1bit
(12.07.2024, 11:33)TomasIha Wrote: This script is the same as mine.
It isn't the same (left is original, right is modified):
Hi, I tried this script. Everything works, but when this value is sent to the modbus register, the other bits of the modbus address also receive values ​​and trigger other device functions. How can change only 8bit value
Check if your device supports function code #22 (Mask Write Register).
If I find out that it supports it, maybe you can give an example of the script
