Threads: 35
There is no rule
Sorting is done via lua table based on key ID which is not visible by user.
Things to improve in the future.
Threads: 57
Good to know. Maybe in the future. I have plans on making possible 100 diagrams, and it would have been nice to sort alfabetically. Maybe have the possibility to search in the list to.
That beeing said, is it possible for me in the meantime to change the lua key ID on the diagrams without screwing up the entire system?
Kai-Roger
Kai-Roger
Threads: 35
Why do you need 100 diagrams? maybe script would simplify it better?
Threads: 35
BTW. Each diagram is generating script or several scripts which you can then look at. As a first step in to scripts you can check what you actually did
With TAGs most of the time we can combine lot of scripts in to one. If you have just 5 types of logic it could end up in 5 scripts
This all depend of what you are doing.
Threads: 8
Keep in mind that those scripts use functions that are not visible, so it might be hard to understand what the script realy does..
Threads: 4
HI,
How can I rename a diagram?
thanks
Threads: 35
Just double click on it.
