bacnet client slowness
I am trying to read/write some values (30ish) in Bacnet to two Isma Controlli modules. I have installed the app, but it seems to be slow in responding (E.g., a binary object goes to 1, and LM receives it after 20 seconds). Could I change something to make this better?
I was told using the lua library is faster, but while trying to load the library it gave me an error "module 'bacnet' not found", so I went and downloaded (hoping the bacnet module was inside) the "genohm-scada-bacnet_20230120_imx6.ipk" with its signature "genohm-scada-bacnet_20230120_imx6.sig" but it says it's not valid. I am lost. EDIT: I was trying to upload it as an app not as a package Tongue
The LM I am using has the latest firmware 2024.04
So what is the current issue?
Make sure to uninstall the app if you use the package and disable bacnet server.
