KNX/TP: Disconnected
We've have a device that has been working fine for years, and now is getting this alerts:
When connecting to the bus (through LM) using ETS, and when we read device states, most responses are lost...
Can it be a SD card issue? Or what can be happening?
It is most likely too big bus traffic.
(16.10.2024, 12:48)Daniel Wrote: It is most likely too big bus traffic.
But when I connect using ETS I can't see a lot of traffic...
What is the bus voltage next to LM? Check the KNX connector.
(16.10.2024, 15:20)Daniel Wrote: What is the bus voltage next to LM? Check the KNX connector.
30.2V
Do you have another KNX psu to try?
(16.10.2024, 16:04)Daniel Wrote: Do you have another KNX psu to try?
Not at the moment... When I go again to the installation I'll try and let you know if it's solved or not.
