22.10.2024, 17:25
I have done a few tests. I will attach my visu backup and gen backup just in case.
MAYBE BUGS
- if in additional values/icons in a dimmer I put in 100% the icon goes back to off instead of being in the last stage. This is easy solvable since if you put 101 as max value this does not happen anymore, but still..
- in tile view, once you change from one plan to another, you return to plan view.
- frame widget does not change in height but only in width
- in a custom widget in compact mode if you select "icon and value" you cannot choose the shape
- there are a few widgets where custom css does not work
IMPROVEMENTS
- it might be that I don't know how to do it but in tile view I feel like I need to see some names otherwise I would just see a bunch of switches I don't know how to identify
- In numeric value display, it might be useful to add a unit field so that when a value is shown you can see the units
QUESTIONS
- how do the functions work (Ex. lights, shades, etc.)?
MAYBE BUGS
IMPROVEMENTS
QUESTIONS
