Threads: 8
Threads: 12
I have used the old method for some years too, but since july I've got the same "401. auth error" as mentioned over here. Thanx for sharing new updated code and instructions. It was not 100% clear to me where to put the code exactly (Before, after, replacing old code)? I replaced the "token", tried to put it before, replacing and after the old user ID/token code with no luck).
Are there new Netatmo instructions with updated code and step by step instructions anywhere available?
Threads: 101
I use this code
Code: require 'ltn12'
require 'socket.http'
json = require("json")
https = require 'ssl.https'
socket.http.TIMEOUT = 5
netatmo_debug = false
client_id = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
client_secret = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
refresh_token_org = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" -- get this token from the netatmo dev page, generate first auth and refresh_token
request_token_url = "https://api.netatmo.net/oauth2/token"
request_url = "https://api.netatmo.net/api"
response_body = { }
if (netatmo_debug) then
log("netatmo start")
-- get auth token from refresh token
-- https://github.com/akbooer/Netatmo/blob/master/L_Netatmo.lua#L430
function refresh_token()
refresh = storage.get('netatmo_refresh_1', refresh_token_org)
local request_body = "grant_type=refresh_token&client_id=" .. client_id .."&client_secret=" .. client_secret .. "&refresh_token=" .. refresh
local body, code, hdrs, stat = https.request
url = request_token_url;
method = "POST";
headers =
["Content-Type"] = "application/x-www-form-urlencoded";
["Content-Length"] = #request_body;
source = ltn12.source.string(request_body);
sink = ltn12.sink.table(response_body);
if (code ~= 200) then
log("netatmo auth error: "..tostring(code)..", "..tostring(body))
return
local response_decode = json.decode(table.concat(response_body))
local access_token = response_decode.access_token
if response_decode.refresh_token then
storage.set('netatmo_refresh_1', response_decode.refresh_token)
log(response_body)
log("netatmo token %s",access_token)
return "access_token=" .. access_token
-- init
if not init then
log("netatmo init")
request_body = refresh_token()
init = true
if not request_body and netatmo_debug then
log("netatmo token error")
function get_stationdata()
if not request_body then return end
--to limit to only one device : -- local request_body = "access_token=" .. access_token .. "&device_id=" .. device_id
--https://dev.netatmo.com/dev/resources/technical/reference/weatherstation/getstationsdata
local response_body = { }
url = request_url..'/getstationsdata';
method = "POST";
headers =
log("netatmo devicelist error: "..tostring(code)..", "..tostring(body)..", "..tostring(hdrs)..", "..tostring(stat))
return
log(response_decode)
log("netatmo end")
Code: require('user.nit_netatmo')
get_stationdata()
Threads: 12
03.08.2023, 20:45
(This post was last modified: 03.08.2023, 21:31 by stemic01.)
Nice. It all seems to connect well and in debug mode I can see the data in table mode. So far so good.
Any code examples how you pull the data and put it into a grp.write for the different modules ? I only figured out the main module and I placed the code just at line "103" . Main station is responding well, but my lack of coding skills does not help if to get the other stations/modules from other rooms/outdoor/rain/Wind etc. I also see that from the Debug log that the tables of the modules (Outdoor, Rain, Wind, Additional room modules) are "Table: Nesting too deep" .
Threads: 30
What do you have in logs?
Threads: 12
04.08.2023, 08:35
(This post was last modified: 04.08.2023, 08:37 by stemic01.
Edit Reason: code view
Code: etatmo Updater 5min 04.08.2023 10:29:34
* string: netatmo start
Netatmo Updater 5min 04.08.2023 10:29:34
* string: netatmo init
* table:
[1]
* string: {"access_token":"**************************","refresh_token":"*********************************|*****************************","scope":["read_station"],"expires_in":10800,"expire_in":10800}
* arg: 1
* string: netatmo token %s
* arg: 2
* string: ***********************************
* string: netatmo end
Netatmo Updater 5min 04.08.2023 10:29:35
* table:
["status"]
* string: ok
["body"]
* table:
["user"]
* table:
["administrative"]
* table:
["country"]
* string: NB_NO
["unit"]
* number: 0
["feel_like_algo"]
* number: 0
["windunit"]
* number: 2
["reg_locale"]
* string: nb-NO
["pressureunit"]
* number: 0
["lang"]
* string: nb
["mail"]
* string: *****@*****.no
["devices"]
* table:
[1]
* table:
["last_setup"]
* number: 1575399707
["_id"]
* string: **:**:**:58:7e:36
["data_type"]
* table:
[1]
* string: Temperature
[2]
* string: CO2
[3]
* string: Humidity
[4]
* string: Noise
[5]
* string: Pressure
["home_name"]
* string: Rorstadvegen
["station_name"]
* string: Rorstadvegen (Indoor1)
["dashboard_data"]
* table:
["time_utc"]
* number: 1691137647
["pressure_trend"]
* string: up
["CO2"]
* number: 474
["Humidity"]
* number: 54
["date_max_temp"]
* number: 1691100162
["max_temp"]
* number: 23.2
["Temperature"]
* number: 22.2
["Noise"]
* number: 40
["Pressure"]
* number: 1007.1
["date_min_temp"]
* number: 1691132810
["min_temp"]
* number: 22.1
["temp_trend"]
* string: stable
["AbsolutePressure"]
* number: 999.6
["home_id"]
* string: ******b7d7e9e4d7
["module_name"]
* string: Indoor1
["firmware"]
* number: 201
["wifi_status"]
* number: 51
["modules"]
* table:
[1]
* table:
["reachable"]
* bool: true
["last_setup"]
* number: 1575399668
["firmware"]
* number: 53
["data_type"]
* table:
nesting too deep
["battery_vp"]
* number: 5332
["_id"]
* string: **:**:**:58:ef:1c
["rf_status"]
* number: 68
["last_seen"]
* number: 1691137641
["last_message"]
* number: 1691137648
["type"]
* string: NAModule1
["battery_percent"]
* number: 63
["dashboard_data"]
* table:
nesting too deep
["module_name"]
* string: Outdoor
[2]
* table:
["reachable"]
* bool: false
["last_setup"]
* number: 1575402173
["firmware"]
* number: 27
["data_type"]
* table:
nesting too deep
["battery_vp"]
* number: 65535
["rf_status"]
* number: 82
["last_seen"]
* number: 1686170566
["last_message"]
["type"]
* string: NAModule2
["battery_percent"]
* number: 100
["_id"]
* string: **:**:**:04:06:6a
["module_name"]
* string: wind
[3]
* table:
["reachable"]
* bool: true
["last_setup"]
* number: 1575486620
["firmware"]
* number: 14
["data_type"]
* table:
nesting too deep
["battery_vp"]
* number: 4854
["_id"]
* string: **:**:**:06:91:0e
["rf_status"]
* number: 88
["last_seen"]
["last_message"]
["type"]
* string: NAModule3
["battery_percent"]
* number: 48
["dashboard_data"]
* table:
nesting too deep
["module_name"]
* string: rain
[4]
* table:
["reachable"]
* bool: true
["last_setup"]
* number: 1581013343
["firmware"]
* number: 53
["data_type"]
* table:
nesting too deep
["battery_vp"]
* number: 5479
["_id"]
* string: **:**:**:59:e9:48
["rf_status"]
* number: 67
["last_seen"]
* number: 1691137635
["last_message"]
["type"]
* string: NAModule4
["battery_percent"]
* number: 71
["dashboard_data"]
* table:
nesting too deep
["module_name"]
* string: bedroom1
[5]
* table:
["reachable"]
* bool: false
["last_setup"]
* number: 1647974577
["firmware"]
* number: 53
["data_type"]
* table:
nesting too deep
["battery_vp"]
* number: 65535
["rf_status"]
* number: 49
["last_seen"]
* number: 1686622420
["last_message"]
* number: 1686622465
["type"]
* string: NAModule4
["battery_percent"]
* number: 100
["_id"]
* string: **:**:**:0c:03:00
["module_name"]
* string: basement
["place"]
* table:
["country"]
* string: NO
["city"]
* string: Oslo
["timezone"]
* string: Europe/Oslo
["location"]
* table:
[1]
* number: *.***************
[2]
* number: 62.*****************
["altitude"]
* number: 63
["co2_calibrating"]
* bool: false
["type"]
* string: NAMain
["date_setup"]
["reachable"]
* bool: true
["last_status_store"]
* number: 1691137650
["time_server"]
* number: 1691137775
["time_exec"]
* number: 0.0466818809509277
Threads: 30
Try these two logs, one should give you Co2, second will show what is deeper under 'modules'.
Code: log(response_decode.body.devices[1].dashboard_data.CO2)
log(response_decode.body.devices[1].modules)
I'm not sure if I used correct order. Yo can play like this by going deeper and deeper in the table.
Threads: 2
I had the same issue, ended up with this solution.
Main module:
grp.write("Netatmo temp stue",response_decode.body.devices[2].dashboard_data.Temperature,dt.float16)
grp.write("Netatmo luftfuktighet stue",response_decode.body.devices[2].dashboard_data.Humidity,dt.scale)
grp.write("Netatmo trykk",response_decode.body.devices[2].dashboard_data.Pressure,dt.uint16)
grp.write("Netatmo CO2 Stue",response_decode.body.devices[2].dashboard_data.CO2,dt.float16)
grp.write("Netatmo db Stue",response_decode.body.devices[2].dashboard_data.Noise,dt.uint8)
Outside temp module:
grp.write("Netatmo temp ute",response_decode.body.devices[2].modules[1].dashboard_data.Temperature,dt.float16)
grp.write("Netatmo luftfuktighet ute",response_decode.body.devices[2].modules[1].dashboard_data.Humidity,dt.scale)
Threads: 11
Hi!
My netatmo script, the old one, doesnt work anymore because they changed there API etc..
I have tried diffrent things but it doesnt work....
Does anyone have a step by step and example script with main module and outdoor module example?
Very nice if there is also in the script examples of how too grp.write to objects on the Logimachine
Thanx!
Threads: 24
(23.11.2023, 14:35)stigen Wrote: Hi!
Thanx!
Hi stigen,
in the first step you need to setup a Netatmo Developer account: https://dev.netatmo.com
Then create a application inside Netatmo development area to get the relevant tokens.
Then generate a new user script, name it "netatmo" and add the token in the following script:
netatmo_debug = true
client_id = "XXX"
client_secret = "xxx"
refresh_token_org = "xxx" -- get this token from the netatmo dev page, generate first auth and refresh_token
response_body = { }
method = "POST";
headers =
return
log(response_body)
-- init
if not init then
log("netatmo init")
init = true
method = "POST";
headers =
return
log(response_decode.body.devices[1].modules[4].dashboard_data)
--write station data to KNX
grp.write("Netatmo_Main_CO2",response_decode.body.devices[1].dashboard_data.CO2)
grp.write("Netatmo_Main_Humidity",response_decode.body.devices[1].dashboard_data.Humidity)
grp.write("Netatmo_Main_Temp",response_decode.body.devices[1].dashboard_data.Temperature)
grp.write("Netatmo_Aussen_Temp",response_decode.body.devices[1].modules[1].dashboard_data.Temperature)
grp.write("Netatmo_Aussen_Humidity",response_decode.body.devices[1].modules[1].dashboard_data.Humidity)
grp.write("Netatmo_Aussen_Battery",response_decode.body.devices[1].modules[1].battery_percent)
grp.write("Netatmo_Bad_Temp",response_decode.body.devices[1].modules[2].dashboard_data.Temperature)
grp.write("Netatmo_Bad_Humidity",response_decode.body.devices[1].modules[2].dashboard_data.Humidity)
grp.write("Netatmo_Bad_Battery",response_decode.body.devices[1].modules[2].battery_percent)
grp.write("Netatmo_Bad_CO2",response_decode.body.devices[1].modules[2].dashboard_data.CO2)
grp.write("Netatmo_Küche_Temp",response_decode.body.devices[1].modules[3].dashboard_data.Temperature)
grp.write("Netatmo_Küche_Humidity",response_decode.body.devices[1].modules[3].dashboard_data.Humidity)
grp.write("Netatmo_Küche_Battery",response_decode.body.devices[1].modules[3].battery_percent)
grp.write("Netatmo_Küche_CO2",response_decode.body.devices[1].modules[3].dashboard_data.CO2)
grp.write("Netatmo_Rain",response_decode.body.devices[1].modules[4].dashboard_data.Rain)
grp.write("Netatmo_Rain_24h",response_decode.body.devices[1].modules[4].dashboard_data.sum_rain_24)
grp.write("Netatmo_Rain_1h",response_decode.body.devices[1].modules[4].dashboard_data.sum_rain_1)
grp.write("Netatmo_Rain_Battery",response_decode.body.devices[1].modules[4].battery_percent)
log("netatmo end")
In the next step you generate scheduled script (*/5****) and add the following code:
Code: require('user.netatmo')
get_stationdata()
Run the scheduled script and looking inside the log which module is the right category (outdoor, rain, wind etc.) and adjust the second number ...body.devices[1].modules [4]... .Furthermore change the object name to your KNX group address name.
Now you are ready to go. I hope it helps.
Best Regards
Steffen
Threads: 2
My netatmo script has stoppet working, any one else having problems?
I det this in log:
Netatmo 19.07.2024 09:58:42
Netatmo 19.07.2024 09:58:43
* string: netatmo auth error: 400, 1
* string: netatmo token error
Threads: 0
(19.07.2024, 07:59)MLa Wrote: Hi,
I det this in log:
Does anyone have the latest version of a working script here? I have copied the script as described in 'Steffen's' post into my Wiser. I created an application via dev.netatmo.com. I also created the objects in Wiser as described in the script. I don't get any error messages in the (error) logs. Who can help?
Thanks in advance!
Threads: 101
07.11.2024, 09:28
(This post was last modified: 07.11.2024, 09:34 by gjniewenhuijse.)
Since 27-10 i received a netatmo auth error: 400, 1
Nothing changed in my config, what happens?
Refresh_toke gives:
Code: * arg: 1
* string: refresh
* arg: 2
* number: 1
* arg: 3
* number: 400
* arg: 4
* table:
["server"]
* string: nginx
["expires"]
* string: 0
["transfer-encoding"]
* string: chunked
["connection"]
* string: close
["strict-transport-security"]
* string: max-age=31536000; includeSubDomains
["cache-control"]
* string: no-cache, must-revalidate
["x-powered-by"]
* string: Netatmo
["date"]
* string: Thu, 07 Nov 2024 09:32:40 GMT
["x-xss-protection"]
* string: 1; mode=block
["access-control-allow-origin"]
* string: *
["content-type"]
* string: application/json
* arg: 5
* string: HTTP/1.1 400
Threads: 30
You should contact Netatmo and ask what they changed.
Threads: 101
problem solved:
generated new token: refresh_token_org
cleared netatmo_refresh_1: storage.set('netatmo_refresh_1', nil)
Threads: 8
Hello, how did you solve it?
I have created a new refresh token but I still have the authentication problem
thanks
Threads: 101
(03.12.2024, 17:47)iridium Wrote: Hi,
thanks
And you also cleared netatmo_refresh_1 storage once?
Threads: 8
(04.12.2024, 12:42)gjniewenhuijse Wrote: (03.12.2024, 17:47)iridium Wrote: Hi,
thanks
Thanks, works!!!
Threads: 12
Another round of Netatmo access and token issues. Sorry, but I can't understand this. I have tried all kind of methods, but can not make it work.
Tried the following methods;
1. Made the Scheduled script with the Require('user.nit_netatmo') and "get_stationdata()" code
2. Made the user.nit_netatmo script (Copied the above code examples, seems to be some few versions in this thread)
3. Refreshed the dev.netatmo.com "Client ID" and "Client secret" from Netatmo and copied into the script
4. Made a "read station" scope and refreshed the "access token" and "refresh token". Pasted in the token to the code
Maybe here is where I go wrong; - Which of the codes are to be used?
Or is it first the access token and and later replace it with the Refresh token? Tried both without success.
5. Tried also to
A) Fully delete the line "storage.set('netatmo_refresh_1', response_decode.refresh_token)" and also tried
B) Change to nil as mentioned over "storage.set('netatmo_refresh_1', nil)" line of code.
Still the following log
Threads: 1
(01.04.2025, 12:24)stemic01 Wrote: Another round of Netatmo access and token issues. Sorry, but I can't understand this. I have tried all kind of methods, but can not make it work.
5. Tried also to
* string: netatmo token error Hello,
I had the same problems.
I generated new access and refresh tokens, replaced the refresh token, and now everything works.
