Http request
I am struggling a litte bit with understanding what is going wrong here:
12345678910111213141516171819202122232425262728293031
function set_light_state(id, is_on)     local url = base_url .. 'devices/' .. id     local payload = json.encode({         {             attributes = {                 isOn = is_on             }         }     })     response_body = {}     local _, code = https.request{         url = url,         method = "PATCH",         headers = {             ["Authorization"] = "Bearer " .. access_token,             ["Content-Type"] = "application/json"         },         source = ltn12.source.string(payload),         sink = ltn12.sink.table(response_body),         verify = false     }     -- Check respnse     if code == 200 then         log('Light was set to ' .. (is_on and 'på' or 'av'))     else         log('Error updating light state. Status code: ' .. tostring(code))         log('Server response: ' .. table.concat(response_body))     end end
The server throws an error when using this function. The response is not helpful as it seems like an internal server error.
I am guessing it has something to do with the payload, as the curl opposite of this function works fine:
curl -X PATCH "https://{IP}}/v1/devices/{ID}" \               -H "Authorization: Bearer BEARER_TOKEN" \               -H "Content-Type: application/json" \               -d '[{"attributes":{"isOn":true}}]' \
Is the payload formatted correctly as in the curl?
You are missing Content-Length header:
["Content-Length"] = #payload,
That did the trick, thank you!
