26.09.2022, 06:09
		Is it possible to export Bacnet-objects from Logic Machine 5 to an EDE-file directly?
Found the export to .csv, but can`t find export to EDE.
					Bacnet export to EDE
		26.09.2022, 06:09
		26.09.2022, 08:52
		This is not implemented, You can use Yabe to export to EDE
		29.09.2022, 11:56
		29.09.2022, 12:03
		EDE is a text/csv format. You can edit it manually and remove unneeded entries.
		29.09.2022, 12:42
		17.12.2024, 08:08
		Anyone of you good at using Yabe? Need some help...
		17.12.2024, 08:46
	(17.12.2024, 08:08)Stig Gøran Bakke Wrote: Anyone of you good at using Yabe? Need some help... Please be more specific of your task.
		17.12.2024, 08:59
	(17.12.2024, 08:46)Daniel Wrote:(17.12.2024, 08:08)Stig Gøran Bakke Wrote: Anyone of you good at using Yabe? Need some help... I'm trying a EDE export from Yabe, but can't get export of all of the objects for some reason. And everytime I try it's different amount of objects that get exported, but never all of them. Maybe some kind of timeout or other network setting that I can't figure out...
		17.12.2024, 09:02
		Is it LM objects that you are exporting? how many? Do you see all of them in YABE while scanning?
		17.12.2024, 09:13
	(17.12.2024, 09:02)Daniel Wrote: Is it LM objects that you are exporting? how many? Do you see all of them in YABE while scanning? In this case it's a Schneider Spacelynk It is 390 objects, and I see all of them in Yabe while scanning. I can also see that they are live with the KNX installation, I can read temp values and write commands, like turn on/off lights. It's just the ede export that seems to not work.
		17.12.2024, 09:24
		I see you already reported this to YABE forum.  Seems like YABE issue as this ede is just export of what is already scanned.  Cant help much here but maybe try to install different versions of YABE.
		17.12.2024, 11:09
(This post was last modified: 17.12.2024, 11:26 by Stig Gøran Bakke.)
		Yeah, trying to get some help with the issue, so trying different forums. Thanks for your help!
Edit: Quick update, tried the same with Yabe version 1.3.1 - everything works fine. So there must be a bug with the EDE export in the 1.3.2 version. (17.12.2024, 11:09)Stig Gøran Bakke Wrote: Yeah, trying to get some help with the issue, so trying different forums. Thanks for your help! Hi! I also have suffered troubles while export EDE from YABE. It not worked correctly for various BACnet devices. But I don't remember the version of YABE I used.  |
