scripitng
Hello guys need your help with a event based script
I have made a event based on group address of the movement of a motion sensor
My client want to when  movement is trigger to turn on the lights of the corridor 1 by 1 with 1 sec delay deference
here is the script that i made but doesnt work and i dont get  any error logs
--event base  off the movement the motion detecor
if event.getvalue(1)
  then
--light 1 without time delay when its on
value = 1
grp.write(0/3/6, value)
  --light 2 with time delay 1 sec when its on
value = 1
os.sleep(1)
grp.write(0/3/7, value)
    --light 3 with time delay 2 sec when its on
value = 1
os.sleep(2)
grp.write(0/3/8, value)
  --light 4 with time delay 3 sec when its on
value = 1
os.sleep(3)
grp.write(0/3/9, value)
  --light 5 with time delay 4 sec when its on
value = 1
os.sleep(4)
  --light 1 with time delay 4 when its off
value = 0
os.sleep(4)
    --light 2 with time delay 3 sec when its off
value = 0
os.sleep(3)
value = 0
os.sleep(2)
    --light 4 with time delay 1 sec when its off
value = 0
os.sleep(1)
  --light 2 without time delay  when its off
value = 0
grp.write(0/3/10, value)
You are missing quotes around group addresses. It should look like this:
grp.write('0/3/6', value)
Other issues:
- Use os.sleep(1) for all delays
- In OFF branch you need to put group addresses in reverse order (from '0/3/10' to '0/3/6')
- Last address in ON branch is incorrect (should be '0/3/10' instead of '0/3/6')
(Yesterday, 11:50)admin Wrote: You are missing quotes around group addresses. It should look like this:
Other issues:
Thank you Very much
Hi Volttech,
you must also use true and false instead of a 1 or 0,
If you use scenes then it is fine.
You can use 1/0 when writing to objects. But you can't compare booleans against 1/0.
