Push notifications from LM to iOS and Android devices
#61
(22.01.2025, 12:35)baggins Wrote:
(22.01.2025, 12:31)mariosp Wrote: hello guys i made this script about DHW temperature for push notification and doesnt work the id is true. Here is the script
local min_temp = '30' local max_temp = '60' local water_temp = event.getvalue() if water_temp <= min_temp   then push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Χαμηλή Θερμοκρασία ΖΝΧ' elseif     water_temp >= max_temp   then   push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Υψηλή Θερμοκρασία ΖΝΧ'     end
and im getting this log : User script:5: attempt to compare number with string stack traceback:
thank you in advance!!
Do not use quotes: local min_temp = 30
i already tried that not the issue ...
The quotes are the issue, remove from 30 and 60 otherwise it is a string not a number.
(22.01.2025, 12:47)Daniel Wrote: The quotes are the issue, remove from 30 and 60 otherwise it is a string not a number.
local min_temp = 30 local max_temp = 60 local water_temp = event.getvalue() if water_temp <= min_temp   then push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Χαμηλή Θερμοκρασία ΖΝΧ' elseif     water_temp >= max_temp   then   push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Υψηλή Θερμοκρασία ΖΝΧ'     end
i tried again it still doent work but i dont get any error
You are not calling push(token, title, body) anywhere in your code.
(22.01.2025, 12:52)admin Wrote: You are not calling push(token, title, body) anywhere in your code.
can you explain more please ? im now learning i appreciate
local min_temp = 30 local max_temp = 60 local water_temp = event.getvalue() if water_temp <= min_temp   then push = require('applibs.lmcloud.push')   token = 'your_token' title = 'Push title' body = 'Χαμηλή Θερμοκρασία ΖΝΧ' res, err = push(token, title, body) log(res, err)  elseif     water_temp >= max_temp   then   push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Υψηλή Θερμοκρασία ΖΝΧ' res, err = push(token, title, body) log(res, err)        end
PS. Do not share your token as anyone with it can send you notification.
Hello!
My problem is that the push notification works, but it doesn't make a sound or wake up the display, it's a quasi-silent notification. I've had this same experience with several phones (iOS). Has anyone had this problem? What could be the solution?
Thank you!
Try again and let us know if something has changed.
(29.01.2026, 17:33)Daniel Wrote: Try again and let us know if something has changed.
It works perfectly now.
Is there any way to set the priority of the push message?
Thanks!
No, there is one globally set and we use the highest.
