Push notifications from LM to iOS and Android devices
#61
(22.01.2025, 12:35)baggins Wrote:
(22.01.2025, 12:31)mariosp Wrote: hello guys i made this script about DHW temperature for push notification and doesnt work the id is true. Here is the script
12345678910111213141516171819202122232425
local min_temp = '30' local max_temp = '60' local water_temp = event.getvalue() if water_temp <= min_temp   then push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Χαμηλή Θερμοκρασία ΖΝΧ' elseif     water_temp >= max_temp   then   push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Υψηλή Θερμοκρασία ΖΝΧ'     end
and im getting this log : User script:5: attempt to compare number with string stack traceback:
thank you in advance!!
Do not use quotes: local min_temp = 30
i already tried that not the issue ...
The quotes are the issue, remove from 30 and 60 otherwise it is a string not a number.
(22.01.2025, 12:47)Daniel Wrote: The quotes are the issue, remove from 30 and 60 otherwise it is a string not a number.
local min_temp = 30 local max_temp = 60 local water_temp = event.getvalue() if water_temp <= min_temp   then push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Χαμηλή Θερμοκρασία ΖΝΧ' elseif     water_temp >= max_temp   then   push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Υψηλή Θερμοκρασία ΖΝΧ'     end
i tried again it still doent work but i dont get any error
You are not calling push(token, title, body) anywhere in your code.
(22.01.2025, 12:52)admin Wrote: You are not calling push(token, title, body) anywhere in your code.
can you explain more please ? im now learning i appreciate
123456789101112131415161718192021222324252627282930
local min_temp = 30 local max_temp = 60 local water_temp = event.getvalue() if water_temp <= min_temp   then push = require('applibs.lmcloud.push')   token = 'your_token' title = 'Push title' body = 'Χαμηλή Θερμοκρασία ΖΝΧ' res, err = push(token, title, body) log(res, errelseif     water_temp >= max_temp   then   push = require('applibs.lmcloud.push')   token = 'ios:d-UdhwTxj05Mqtku6GH0JU:APA91bGK4SoVNL4AOg20RQTC2DiUMYtbjrk6YhsVPQoP9nDpgboWDpTQO0G6ruMHq2xXwccyI1LsyJL3kflVsfCjzvcrQspFTUOlqLfpjap4dAnHHSF9tE4' title = 'Push title' body = 'Υψηλή Θερμοκρασία ΖΝΧ' res, err = push(token, title, body) log(res, err)        end
PS. Do not share your token as anyone with it can send you notification.
