backup to FTP every night -sdcard
just a question.
I was questionning about doing backup everyday to our ftp of our customer.
Can it be a SDcard killer?
Here some part of our script with archive creation and cleaning file.
-- prepare files for backup os.execute('sh /lib/genohm-scada/web/general/backup.sh') -- create archive os.execute('cd /lib/genohm-scada/storage && tar -c -z -f ' .. dst .. ' ./') ...... ...... -- cleanup os.execute('cd /home/ftp && rm -rf backup-*') --os.execute('cd /home/ftp && rm -rf backup_*') --Line 42 is incorrect. It leads to old backups not being removed. --os.execute('cd /lib/genohm-scada/storage && rm -rf user userlib.luas blockly.luas initscript.lua helpers.js genohm-scada.config filter*')
SE ECO EXPERT
Your script is outdated, use this: https://kb.logicmachine.net/scripting/ba...email-ftp/
ok.
your so quick :-))
So with this scipt no problem to backup everyday
because there is still a temp file created, no ?
path = 'backups/LM-' .. os.date('%Y-%m-%d') .. '.zip'
or backups/ are in memory ?
EDIT:
my mistake path are remote folder
SE ECO EXPERT
(20.11.2024, 08:40)admin Wrote: Your script is outdated, use this: https://kb.logicmachine.net/scripting/ba...email-ftp/
Hello Admin
Is it possible to set a master password to the .zip exported file?
Best Regards,
Replace:
data = webrequest('general', 'backup')
With:
data = webrequest('general', 'backup', {   password = '123456' })
many thanks admin
Best Regards,
Hello Dears
I create a scheduled script for automatic backup.
But I find the recent backup created  with 0kb size!
why could this issue happened while I didn't get any error result.
Best Regards,
Log what webrequest and ftp.put return:
webrequest = require('webrequest') data, err = webrequest('general', 'backup', { password = '123456' }) log(type(data) == 'string' and #data or 'error', err) res, err = ftp.put({   host = host,   user = user,   password = pass,   argument = path,   source = ltn12.source.string(data) }) log(res, err)
Hello Admin,
Both return same result
* arg: 1   * number: 11578924 * arg: 2   * nil
Please note that this issue happened once not always, but I want to be notified if the backup generated with 0KB.
I will try and If I succeed reproducing the case I will send you the log result
Best Regards,
Hello Admin,
I tried several times to replicate the issue but unfortunately I couldn't.
could I use the this line of code if err for notification if this issue happened again
Best Regards,
Use this for error logging:
if type(data) ~= 'string' then   log('backup failed', err) elseif #data == 0 then   log('empty backup', err) end
