WoL script problem
Bug
Is there any simple Wake-On-Lan script, to wake PC by Logic Machine?
I tried to use code from thread:
http://forum.logicmachine.net/showthread...light=wake
but it doesn't work.
Just found a working script:
function wol_send(mac_dest)  local mac = ''  for w in string.gmatch(mac_dest, "[0-9A-Za-z][0-9A-Za-z]") do    mac = mac .. string.char(tonumber(w, 16))  end  local udp = require("socket").udp()  udp:settimeout(1)  udp:setoption("broadcast", true)  udp:sendto(string.char(0xff):rep(6) .. mac:rep(16) , '255.255.255.255', 9)   end
CASE CLOSED  Smile
Have you actually checked that WOL works? This script doesn't work for me on the latest FW, it requires some changes to the socket library to make it work.
(21.03.2017, 07:15)admin Wrote: Have you actually checked that WOL works? This script doesn't work for me on the latest FW, it requires some changes to the socket library to make it work.
Yes, with this script (bottom one) I can wake NUC PC without any changes.
We are using LM5 lite which we received last week, so it should be latest FW i think.
