email sending
Morning i'm trying to send Email
i followed the steps in the manuel attached, but i can't send email
.pdf   AN011_Wiser_for_KNX_SMS_Mail_Flash_v.1.1.pdf (Size: 748.23 KB / Downloads: 43)
Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911
Are you using gmail? If yes did you created an app password in your gmail account and use that in your script?
(05.05.2025, 08:48)Daniel Wrote: Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911
This is what i have from log
* arg: 1
  * nil
* arg: 2
  * string: 535-5.7.8 Username and Password not accepted. For more information, go to
535 5.7.8  https://support.google.com/mail/?p=BadCredentials 4fb4d7f45d1cf-5fa77bf1e35sm8035646a12.66 - gsmtp
This is the function i used :
function Email(to, subject, message)
  ---------------BEGINNING OF USER EDITABLE AREA-------------------
  local settings = {
    from = 'nguenangulrich6@gmail.com',
    -- smtp username
    user = 'nguenangulrich6@gmail.com',
    -- smtp password
    password = '***',
    -- smtp server
    server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    secure = 'sslv23',
  -------------------END OF USER EDITABLE AREA---------------------
  local escape = function(v)
    return '<' .. tostring(v) .. '>'
  -- message headers and body
    headers = {
      to = escape(to),
      subject = subject,
    body = message
  -- fixup from field
  settings.from = escape(settings.from)
  settings.rcpt = { escape(to) }
  return smtp.send(settings)
the gmail acount i created is "nguenangulrich6@gmail.com" and the pasword "***"
(05.05.2025, 08:55)Erwin van der Zwart Wrote: Are you using gmail? If yes did you created an app password in your gmail account and use that in your script?
Yes, like in the above message
You need to enable 2FA and the create app password: https://myaccount.google.com/apppasswords
When adding password to your script remove all spaces so only 16 characters are left.
* arg: 1
  * nil
* arg: 2
  local settings = {
    -- smtp username
    -- smtp password
    password = '***',
    -- smtp server
    -- smtp server port
    port = 465,
    secure = 'sslv23',
    headers = {
      to = escape(to),
      subject = subject,
    body = message
  -- fixup from field
Thank's, it's OK now
Morning to everyone,
I tryed to do the same script, in my Comm Funct, I have:
function mail(to, subject, message)
  local settings = {
    from ='al*******@gmail.com',
    -- smtp username
    user = 'LM********',
    -- smtp password
    password = '********',
    -- smtp server
    -- smtp server port
    port = 465,
   -- secure = 'tlsv1_2',
    secure = 'sslv23'
    return '<'..tostring..'>'
--  if type(to) ~= 'table' then
--   to = { to }
  --end
-- for index, email in ipairs(to) do
   -- to[ index ] = '<' .. tostring(email) .. '>'
  --end
  -- Fixup from field
-- local from = '<' ..tostring(settings.from)..'>'
      headers = {
     -- to = table.concat(to, ', '),
        to = escape(to),
        subject = subject,
        --['From'] = settings.from,
        ['From'] = from,
      ['Content-type'] = 'text/html; charset=utf-8',
    body = message
  -- fixup from field
  --settings.from = '<' .. tostring(settings.from) .. '>'
-- settings.from = from
  --settings.rcpt = to
  settings.rcpt = { escape(to)}
And in my Event-Script I have:
curr_value = event.getvalue()
prev_value = storage.get('prev_value')
if curr_value == prev_value then
  return
storage.set('prev_value', curr_value)
os.sleep(10)
if curr_value then
  subject = 'Main switch = PERMIT'
  message = '\nState: Desbloqueado'
  subject = 'Main switch = PROHIBIT'
  message = '\nState: BLOQUEADO!!'
mail('ju*********@gmail.com', subject, message)
The problem is that when I Run my Event script, I don't have any Log or Error, but I neither recive any e-mail in my account.
I will appreciate the help!
Use this to get the result/error in Logs tab.
res, err = mail('ju*********@gmail.com', subject, message)
log(res, err)
Don't randomly change the mail() function. You only need to change the settings table, everything else should be kept as is. In your case the 'From' header is invalid because the assigned variable is not defined.
(27.11.2025, 11:32)admin Wrote: Use this to get the result/error in Logs tab.
log(res, err)
Thanks for the point. I forgot to include the log, but when I run the script again, I get no response from either the log or the error log, even though I added the log before running it. I'm also not receiving the email. I've also removed the "From" from the message body, so it now looks like this (in Comm Func) :
  local settings = {
    from ='al************@gmail.com',
    -- smtp username
    user = 'LM**********',
    -- smtp password
    password = 's************',
    -- smtp server
    -- smtp server port
    port = 465,
    secure = 'sslv23'
    return '<' .. tostring .. '>'
      headers = {
        to = escape(to),
        subject = subject,
    body = message
From header is required, mail sending won't work without it. Temporarily modify the event script so it only sends the email without checking the previous value and waiting for 10 seconds.
(27.11.2025, 11:55)admin Wrote: From header is required, mail sending won't work without it. Temporarily modify the event script so it only sends the email without checking the previous value and waiting for 10 seconds.
Almost fixed, now it's sending me the same error that the collegue:
Quote: * string: 535-5.7.8 Username and Password not accepted. For more information
I already change the user name and the password, I delete the spaces from the password and give the same name that I use when i create the app password, the "app name"
Username should be the same as the sending email (from), including @gmail.com
The app password should be 16 characters without spaces.
(27.11.2025, 12:18)admin Wrote: Username should be the same as the sending email (from), including @gmail.com
Thank you very much!
It's working!  Smile
