reactor not get ip from GSM
#21
Not System log but LM Logs tab. Disable all other scripts and disable 3g/4g connection. Keep only one test script active. Reboot LM just in case.
Hello!
I have a very similar problem.
It won't connect to the GSM network and I can't send SMS with it. I tried with two different SIM cards but it didn't work either. In the "system log" I get this error message:
May 5 10:59:16 LogicMachine daemon.notice pppd[1684]: pppd 2.4.9 started by root, uid 0 May 5 10:59:13 LogicMachine daemon.info pppd[1682]: Exit. May 5 10:59:12 LogicMachine daemon.err pppd[1682]: Connect script failed May 5 10:59:11 LogicMachine daemon.notice pppd[1682]: pppd 2.4.9 started by root, uid 0 May 5 10:59:08 LogicMachine daemon.info pppd[1680]: Exit. May 5 10:59:07 LogicMachine daemon.err pppd[1680]: Connect script failed May 5 10:59:05 LogicMachine daemon.notice pppd[1680]: pppd 2.4.9 started by root, uid 0
This is the log I got for the first script you posted earlier:
* string: AT&F OK +CPIN: SIM PIN ATE1 OK AT+CGDCONT=1,"IP","online" ERROR ATD*99***1# ERROR
And for the second script, this:
* string: AT&F OK +CPIN: SIM PIN ATE1 OK AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR AT+CSQ +CSQ: 31,99 OK AT+CPIN? +CPIN: SIM PIN OK AT+COPS? ERROR
What could be the problem?
Thank You!
Test script won't work if PIN is enabled. Disable PIN protection on the SIM card and run the script again.
(05.05.2025, 11:15)admin Wrote: Test script won't work if PIN is enabled. Disable PIN protection on the SIM card and run the script again.
Yes, the script works without PIN protection.
The GSM network also started working immediately.
Shouldn't the services work with PIN protection, or did I mess something up?
* string: AT&F OK +CPIN: READY SMS DONE PB DONE ATE1 OK AT+CSQ +CSQ: 20,99 OK AT+CPIN? +CPIN: READY OK AT+COPS? +COPS: 0,0,"Yettel HU Yettel HU",7 OK
Thank You!
PIN issue will be fixed in the next firmware release. For now SIM PIN protection must be disabled.
