email sending
Morning i'm trying to send Email
i followed the steps in the manuel attached, but i can't send email
.pdf   AN011_Wiser_for_KNX_SMS_Mail_Flash_v.1.1.pdf (Size: 748.23 KB / Downloads: 21)
Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911
Are you using gmail? If yes did you created an app password in your gmail account and use that in your script?
(05.05.2025, 08:48)Daniel Wrote: Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911
This is what i have from log
* arg: 1
  * nil
* arg: 2
  * string: 535-5.7.8 Username and Password not accepted. For more information, go to
535 5.7.8  https://support.google.com/mail/?p=BadCredentials 4fb4d7f45d1cf-5fa77bf1e35sm8035646a12.66 - gsmtp
This is the function i used :
function Email(to, subject, message)
  ---------------BEGINNING OF USER EDITABLE AREA-------------------
  local settings = {
    from = 'nguenangulrich6@gmail.com',
    -- smtp username
    user = 'nguenangulrich6@gmail.com',
    -- smtp password
    password = '***',
    -- smtp server
    server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    secure = 'sslv23',
  -------------------END OF USER EDITABLE AREA---------------------
  local escape = function(v)
    return '<' .. tostring(v) .. '>'
  -- message headers and body
    headers = {
      to = escape(to),
      subject = subject,
    body = message
  -- fixup from field
  settings.from = escape(settings.from)
  settings.rcpt = { escape(to) }
  return smtp.send(settings)
the gmail acount i created is "nguenangulrich6@gmail.com" and the pasword "***"
(05.05.2025, 08:55)Erwin van der Zwart Wrote: Are you using gmail? If yes did you created an app password in your gmail account and use that in your script?
Yes, like in the above message
You need to enable 2FA and the create app password: https://myaccount.google.com/apppasswords
When adding password to your script remove all spaces so only 16 characters are left.
* arg: 1
  * nil
* arg: 2
  local settings = {
    -- smtp username
    -- smtp password
    password = '***',
    -- smtp server
    -- smtp server port
    port = 465,
    secure = 'sslv23',
    headers = {
      to = escape(to),
      subject = subject,
    body = message
  -- fixup from field
Thank's, it's OK now
