Ondilo spa/pool monitor
Please, can anyone help with connecting a Ondilo spa monitor.
Authentication is to difficult for me Wink
Here the api info how to auth: https://interop.ondilo.com/docs/api/cust...entication
And here's the general api info: https://interop.ondilo.com/docs/api/customer/v1/
I have a app username and password but i see nothing in the doc how to get access to the api with that user&pwd
Ok, i give it a try
my code:
local usr = "my@email.com"
local pwd = "mypwd"
local uri = "https%3A%2F%2Fyour.app.url%2Fauthorize" -- there's no url redirect, so how to handle this
local state = "c7d37ee542c7'" -- random
---------------------------- change nothing after this line -------------------------------
local apiHost = "https://interop.ondilo.com"
local apiUrl = apiHost .. "/api/customer/v1"
local endpointToken = "/oauth2/token"
local endpointAuth = "/oauth2/authorize"
-- init
if not init then
  require('socket.http')
  require('ltn12')
  require('json')
  socket.http.TIMEOUT = 5
  init = true
function getAuth()
  url = apiHost..endpointAuth..'?client_id=customer_api&response_type=code&redirect_uri='..uri..'&scope=api&state='..state
  method = "POST"
  local response_body = { }
  local payload = '{"login":"'..usr..'","password":"'..pwd..'","locale":"nl","proceed":"Authorize"}'
  local res, code, response_headers, status = socket.http.request
    url = url,
    method = method,
    headers =
      ["Accept"] = "application/json",
      ["Accept-Charset"] = "utf-8",
      ["Accept-Encoding"] = "gzip-deflate",
      ["Content-Type"] = "application/json",
      ["Content-Length"] = payload:len()
    source = ltn12.source.string(payload),
    sink = ltn12.sink.table(response_body)
  log(res, code, response_headers, status)
  log(response_body)
getAuth()
My return:
* arg: 1
  * number: 1
* arg: 2
  * number: 200
* arg: 3
  * table:
   ["server"]
    * string: Apache/2.4.29 (Ubuntu)
   ["content-type"]
    * string: text/html;charset=UTF-8
   ["connection"]
    * string: close
   ["access-control-allow-methods"]
    * string: GET, POST, PUT, PATCH, DELETE, OPTIONS
   ["access-control-allow-headers"]
    * string: X-Requested-With, Content-Type, Accept, Origin, Authorization
   ["cache-control"]
    * string: no-store, no-cache, must-revalidate, max-age=0, post-check=0, pre-check=0
   ["pragma"]
    * string: no-cache
   ["content-length"]
    * string: 4047
   ["date"]
    * string: Wed, 21 Oct 2020 17:45:44 GMT
   ["vary"]
    * string: Accept-Encoding
   ["access-control-allow-origin"]
    * string:
   ["access-control-allow-credentials"]
    * string: true
* arg: 4
  * string: HTTP/1.1 200 OK
but how to get the code that is normally send to the url given in the var uri (see above) or is my code wrong?
documentation is here: https://interop.ondilo.com/docs/api/cust...entication
if i do the same in a browser, my return url looks like:
https://your.app.url/authorize?code=6440...a88c&state=c7d37ee542c7
What do you get in response body? You should also remove Accept-Encoding header otherwise body will be compressed with gzip instead of plain text.
(22.10.2020, 06:30)admin Wrote: What do you get in response body? You should also remove Accept-Encoding header otherwise body will be compressed with gzip instead of plain text.
I see the plain website, i think the form is not filled and executed. But how to do this.
same source as:
https://interop.ondilo.com/oauth2/author...d44ef532c5
* table:
[1]
  * string:
<!DOCTYPE html>
<html>
    <head>
        <meta charset="utf-8"/>
        <title>Ondilo authorization page</title>
        <style>
                margin: 10px 4px 10px 4px;
            .box {
                width: 340px;
                margin: auto;
                border: 1px solid rgb(41, 165, 155);
            .banner {
                margin: 0px;
                background-color: rgb(41, 165, 155);
                height: 50px;
                position: relative;
            .ico {
                position: absolute;
                top: 3px;
                left: 4px;
            .ondilo {
                position: absolute;
                top: -1px;
                right: 4px;
            strong {
                margin: 0px;
            label {
                margin-top: 8px;
                margin-bottom: 0px;
                display: block;
                font-size: 0.8em;
                color: gray;
            input, select {
                font-size: 1.2em;
            input[type=text], input[type=password], select {
                width: 312px;
            input[type=submit] {
                width: 322px;
                display: block;
                margin-bottom: 25px;
            .authorize {
                color: white;
                margin-bottom: 10px;
                margin-top: 25px;
                border-color: rgb(41, 165, 155);
            p {
                text-align: center;
                margin-top: 25px;
            .warning p, .warning ul {
                margin: 0 0 0 0;
                line-height: 15px;
        </style>
    </head>
    <body>
        <div class="box">
            <div class="banner">
                <img src="/images/ico.png" alt="ICO" title="ICO" class="ico"/
[2]
  * string: >
                <img src="/images/ondilo.png" alt="Ondilo" title="Ondilo" class="ondilo"/>
            </div>
                        <form method="post">
                <p>Sign in to allow <strong>customer_api</strong> to connect to your <strong>Ondilo</strong> account and access the related data</p>
                <label for="login">Your email address</label><input type="text" name="login" ><br/>
                <label for="pasword">Your password</label><input type="password" name="password">
                <label for="locale">Your language</label><select id="locale" name="locale">
                    <option value="en">English</option>
                    <option value="fr">Français</option>
                    <option value="es">Español</option>
                    <option value="de">Deutsch</option>
                    <option value="pt">Português</option>
                    <option value="nl">Nederlands</option>
                    <option value="it">Italiano</option>
                    <option value="cs">Čeština</option>
                    <option value="hu">Magyar</option>
                    <option value="sv">Svenska</option>
                    <option value="ro">Română</option>
                </select>
                <div class="warning">
                    <p>
                        We remind that ICO takes measures every hour.</br>
                        In order to avoid excessive load of our servers, the requests to the Ondilo Customer API are limited to the following per user quotas :
                        <ul>
                            <li>5 requests per second</li>
                            <li>30 requests per hour</li>
                        </ul>
                    </p>
                </div>
                <input type="submit" name="proceed" value="Authorize" class="authorize">
                <input type="submit" name="proceed" value="Cancel">
            </form>
        </div>
    </body>
</html>
For auth you need to use standard POST, not JSON:
function encodepost(t)
  local res = {}
  local esc = require('socket.url').escape
  for k, v in pairs(t) do
    res[ #res + 1 ] = esc(k) .. '=' .. esc(v)
  return table.concat(res, '&')
payload = encodepost({
  login = usr,
  password = pwd,
  locale = "nl",
  proceed = "Authorize",
For this request Accept/Content-Type headers are not needed. Add redirect = false to the request table to catch the redirect URL instead of following it.
(22.10.2020, 07:14)admin Wrote: For auth you need to use standard POST, not JSON:
mmm same result with changed code
function getAuth()
    local res = {}
  method = "POST"
  local response_body = {}
  local payload = encodepost({
    login = usr,
    password = pwd,
    locale = "nl",
    url = url,
    method = method,
    redirect = false,
    headers =
      ["Content-Length"] = #payload
  if res and code == 200 then
    log(response_body)
Header is missing:
["Content-Type"] = "application/x-www-form-urlencoded"
(22.10.2020, 08:23)admin Wrote: Header is missing:
 yes, now i get the authorization code (authCode).
Next is exchaging the authorization code for an access token, see my code try below.
Doc: https://interop.ondilo.com/docs/api/cust...n-exchange
-- exchange the authorization code for an access token
  if authCode then
    url = apiHost..endpointToken..'?code='..authCode..'&grant_type=authorization_code&client_id=customer_api&redirect_uri='..uri
    method = "POST"
      url = url,
      method = method,
      headers =
      source = ltn12.source.string(''),
but as usually i received an error  Big Grin
* arg: 1
  * number: 1
* arg: 2
  * number: 400
* arg: 3
  * table:
   ["server"]
   ["content-type"]
    * string: application/json
   ["connection"]
    * string: close
   ["cache-control"]
   ["pragma"]
    * string: no-cache
   ["date"]
    * string: Thu, 22 Oct 2020 11:14:32 GMT
   ["content-length"]
    * string: 97
    * string: *
    * string: true
* arg: 4
  * string: HTTP/1.1 400 Bad Request
You must provide "Content-Length" header for POST requests. Move your GET variables to POST payload:
  code = authCode,
  grant_type = 'authorization_code',
  client_id = 'customer_api',
  redirect_uri = uri,
many thanks to admin for the support.
here my first version to get the latest sensor readings for one pool/spa.
Access tokens have a lifetime of one hour, while refresh tokens are non-expiring.
.lua   ondilo.lua (Size: 4.25 KB / Downloads: 29)
One small improvement, you should use the whole table instead of only the first element. If the JSON response is large enough then the response table will have more than 1 element. Use this instead:
data = json.decode(table.concat(response_body))
Hello
Could you give some instructions with examples how to get sensors data please  Shy
I am not familiar with scripting, but can multiply solution from example.
Thank you
First you need to set usr and pwd variables in the script. Then run this function to get the ID of your pool:
log( getPoolInfo() )
Then you can request the sensor state by calling getSensorInfo:
data = getSensorInfo()
log(data)
When the data format is known the script can be modified to write sensor state to objects.
(24.05.2021, 09:38)admin Wrote: First you need to set usr and pwd variables in the script. Then run this function to get the ID of your pool:
log(data)
Hello
I have got sensors data, thank you, could you make example of a function for the PUT method?
Thank you
PUT is the same as POST, just change the method field accordingly
I know that this question is quite some time later than the last post, but is this code still usable or is the API changed? I got respons 419 when getAuth() is triggered.
Respons_body:
* table:
[1]
  * string: <!DOCTYPE html>
<html lang="en">
    <head>
        <meta charset="utf-8">
        <meta name="viewport" content="width=device-width, initial-scale=1">
        <title>Page Expired</title>
        <style>
            /*! normalize.css v8.0.1 | MIT License | github.com/necolas/normalize.css */html{line-height:1.15;-webkit-text-size-adjust:100%}body{margin:0}a{background-color:transparent}code{font-family:monospace,monospace;font-size:1em}[hidden]{display:none}html{font-family:system-ui,-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Helvetica Neue,Arial,Noto Sans,sans-serif,Apple Color Emoji,Segoe UI Emoji,Segoe UI Symbol,Noto Color Emoji;line-height:1.5}*,:after,:before{box-sizing:border-box;border:0 solid #e2e8f0}a{color:inherit;text-decoration:inherit}code{font-family:Menlo,Monaco,Consolas,Liberation Mono,Courier New,monospace}svg,video{display:block;vertical-align:middle}video{max-width:100%;height:auto}.bg-white{--bg-opacity:1;background-color:#fff;background-color:rgba(255,255,255,var(--bg-opacity))}.bg-gray-100{--bg-opacity:1;background-color:#f7fafc;background-color:rgba(247,250,252,var(--bg-opacity))}.border-gray-200{--border-opacity:1;border-color:#edf2f7;border-color:rgba(237,242,247,var(--border-opacity))}.border-gray-400{--border-opacity:1;border-color:#cbd5e0;border-color:rgba(203,213,224,var(--border-opacity))}.border-t{border-top-width:1px}.border-r{border-right-width:1px}.flex{display:flex}.grid{display:grid}.hidden{display:none}.items-center{align-items:center}.justify-center{justify-content:center}.font-semibold{font-weight:600}.h-5{height:1.25rem}.h-8{height:2rem}.h-16{height:4rem}.text-sm{font-size:.875rem}.text-lg{font-size:1.125rem}.leading-7{line-height:1.75rem}.mx-auto{margin-left:auto;margin-right:auto}.ml-1{margin-left:.25rem}.mt-2{margin-top:.5rem}.mr-2{margin-right:.5rem}.ml-2{margin-left:.5rem}.mt-4{margin-top:1rem}.ml-4{margin-left:1rem}.mt-8{margin-top:2rem}.ml-12{margin-left:3rem}.-mt-px{margin-top:-1px}.max-w-xl{max-width:36rem}.max-w-6xl{max-width:72rem}.min-h-screen{min-height:100vh}.overflow-hidden{overflow:hidden}.p-6{padding:1.5rem}.py-4{padding-top:1rem;padding-bottom:1rem}.px-4{padding-left:1rem;padding-right:1rem}.px-6{padding-left:1.5rem;padding-right:1.5rem}.pt-8{padding-top:2rem}.fixed{position:fixed}.relative{position:relative}.top-0{top:0}.right-0{right:0}.shadow{box-shadow:0 1px 3px 0 rgba(0,0,0,.1),0 1px 2px 0 rgba(0,0,0,.06)}.text-center{text-align:center}.text-gray-200{--text-opacity:1;color:#edf2f7;color:rgba(237,242,247,var(--text-opacity))}.text-gray-300{--text-opacity:1;color:#e2e8f0;color:rgba(226,232,240,var(--text-opacity))}.text-gray-400{--text-opacity:1;color:#cbd5e0;color:rgba(203,213,224,var(--text-opacity))}.text-gray-500{--text-opacity:1;color:#a0aec0;color:rgba(160,174,192,var(--text-opacity))}.text-gray-600{--text-opacity:1;color:#718096;color:rgba(113,128,150,var(--text-opacity))}.text-gray-700{--text-opacity:1;color:#4a5568;color:rgba(74,85,104,var(--text-opacity))}.text-gray-900{--text-opacity:1;color:#1a202c;color:rgba(26,32,44,var(--text-opacity))}.uppercase{text-transform:uppercase}.underline{text-decoration:underline}.antialiased{-webkit-font-smoothing:antialiased;-moz-osx-font-smoothing:grayscale}.tracking-wider{letter-spacing:.05em}.w-5{width:1.25rem}.w-8{width:2rem}.w-auto{width:auto}.grid-cols-1{grid-template-columns:repeat(1,minmax(0,1fr))}@-webkit-keyframes spin{0%{transform:rotate(0deg)}to{transform:rotate(1turn)}}@keyframes spin{0%{transform:rotate(0deg)}to{transform:rotate(1turn)}}@-webkit-keyframes ping{0%{transform:scale(1);opacity:1}75%,to{transform:scale(2);opacity:0}}@keyframes ping{0%{transform:scale(1);opacity:1}75%,to{transform:scale(2);opacity:0}}@-webkit-keyframes pulse{0%,to{opacity:1}50%{opacity:.5}}@keyframes pulse{0%,to{opacity:1}50%{opacity:.5}}@-webkit-keyframes bounce{0%,to{transform:translateY(-25%);-webkit-animation-timing-function:cubic-bezier(.8,0,1,1);animation-timing-function:cubic-bezier(.8,0,1,1)}50%{transform:translateY(0);-webkit-animation-timing-function:cubic-bezier(0,0,.2,1);animation-timing-function:cubic-bezier(0,0,.2,1)}}@keyframes bounce{0%,to{transform:translateY(-25%);-webkit-animation-timing-function:cubic-bezier(.8,0,1,1);animation-timing-function:cubic-bezier(.8,0,1,1)}50%{transform:translateY(0);-webkit-animation-timing-function:cubic-bezier(0,0,.2,1);animation-timing-function:cubic-bezier(0,0,.2,1)}}@media (min-width:640px){.sm\:rounded-lg{border-radius:.5rem}.sm\:block{display:block}.sm\:items-center{align-items:center}.sm\:justify-start{justify-content:flex-start}.sm\:justify-between{justify-content:space-between}.sm\:h-20{height:5rem}.sm\:ml-0{margin-left:0}.sm\:px-6{padding-left:1.5rem;padding-right:1.5rem}.sm\:pt-0{padding-top:0}.sm\:text-left{text-align:left}.sm\:text-right{text-align:right}}@media (min-width:768px){.md\:border-t-0{border-top-width:0}.md\:border-l{border-left-width:1px}.md\:grid-cols-2{grid-template-columns:repeat(2,minmax(0,1fr))}}@media (min-width:1024px){.lg\:px-8{padding-left:2rem;padding-right:2rem}}@media (prefers-color-scheme:dark){.dark\:bg-gray-800{--bg-opacity:1;background-color:#2d3748;background-color:rgba(45,55,72,var(--bg-opacity))}.dark\:bg-gray-900{--bg-opacity:1;background-color:#1a202c;background-color:rgba(26,32,44,var(--bg-opacity))}.dark\:border-gray-700{--border-opacity:1;border-color:#4a5568;border-color:rgba(74,85,104,var(--border-opacity))}.dark\:text-white{--text-opacity:1;color:#fff;color:rgba(255,255,255,var(--text-opacity))}.dark\:text-gray-400{--text-opacity:1;color:#cbd5e0;color:rgba(203,213,224,var(--text-opacity))}}
        </style>
        <style>
            body {
                font-family: ui-sans-serif, system-ui, -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, "Helvetica Neue", Arial, "Noto Sans", sans-serif, "Apple Color Emoji", "Segoe UI Emoji", "Segoe UI Symbol", "Noto Color Emoji";
        </style>
    </head>
    <body class="antialiased">
        <div class="relative flex items-top justify-center min-h-screen bg-gray-100 dark:bg-gray-900 sm:items-center sm:pt-0">
            <div class="max-w-xl mx-auto sm:px-6 lg:px-8">
                <div class="flex items-center pt-8 sm:justify-start sm:pt-0">
                    <div class="px-4 text-lg text-gray-500 border-r border-gray-400 tracking-wider">
                        419                    </div>
                    <div class="ml-4 text-lg text-gray-500 uppercase tracking-wider">
                        Page Expired                    </div>
                </div>
            </div>
        </div>
    </body>
</html>
same problem here
Try this as a starting point to get the token:
function getAuth()
  local url = apiHost..endpointAuth..'?client_id=customer_api&response_type=code&redirect_uri='..uri..'&scope=api&state='..state
  local resp, code, hdrs, stat = socket.http.request(url = url)
  local formtoken = resp:match('name="_token" value="([^"]+)">')
  local cookies = hdrs['set-cookie'] or ''
  local cookietoken = cookies:match('XSRF%-TOKEN=[^;]+') or ''
  local cookiesession = cookies:match('interop_new_api_session=[^;]+') or ''
  local escape = require('socket.url').escape
  local data = {
    '_token=' .. formtoken,
    'email=' .. escape(usr),
    'password=' .. escape(pwd),
    'locale=en',
    'proceed=Authorize'
  local body = table.concat(data, '&')
  local resp, code, hdrs, stat = socket.http.request({
    url = url,
    method = 'POST',
    headers = {
      ['Content-Type'] = 'application/x-www-form-urlencoded',
      ['Content-Length'] = #body,
      ['Referer'] = url,
      ['Cookie'] = cookietoken .. '; ' .. cookiesession,
    body = body
  log(resp)
  log(code)
  log(hdrs)
Thank you! Smile
