Threads: 1
I'm trying to reboot a wiser for KNX with a script.
Using this "os.execute('reboot')", the server doesn't reboot.
I also tested this "os.execute(reboot)" but i have the same result.
Respectfully,
BRUN Félix.
Threads: 28
In General configuration there is Block unsafe functions in scripts:
Make sure to disable it.
Threads: 21
I have the same problem as fbrun@domizy to reboot LM5, I don't understand Daniel's answer
Jean-Marc
Threads: 28
Utilities-> General configuration...
Threads: 21
24.06.2025, 15:18
(This post was last modified: 24.06.2025, 15:23 by JMM.)
Thanks Daniel, it's OK
Is it also possible to reset the USB port by script, I have a Uart rs232 which from time to time blocks and I am obliged to unplug and replug
Jean-Marc
Threads: 28
What is the device you have problem with?
Threads: 21
It's : FTDI - FT232R USB UART
Jean-Marc
Threads: 28
Did you check if just reboot helps? I think it will need power down anyway.
Threads: 21
24.06.2025, 16:03
(This post was last modified: 24.06.2025, 16:04 by JMM.)
Yes reboot helps, I read the frame of a Linky electric meter every minute, some day at 8:00 a.m. the meter sends the tariff change and the ft232 blocks so either reboot or disconnect reconnect
It's not from the script!!
Jean-Marc
