[RELEASE] LogicMachine firmware 2024.04
#41
(01.10.2024, 08:23)admin Wrote: Most likely your device does not send the username/password explicitly so the request fails. A temporary work-around via .lp script: https://forum.logicmachine.net/showthrea...7#pid20407
Next firmware will have an option to fix this issue.
Thanks, for now it works.
I discovered that since the upgrade, all modbus mappings now have a precision of 0.2 at best, which effectively breaks any trends or live values with a higher precision then that such as power readings in kW or power factor. It's also really odd that this was forced on existing mappings?
Could this please be fixed?
Thanks!
Install Modbus profile app, you can lower it trough the app.
You will need updated package too
https://dl.openrb.com/pkg/genohm-scada-m...6_imx6.ipk
https://dl.openrb.com/pkg/genohm-scada-m...6_imx6.sig
Hi Team,
I have some trouble on scene page, it will work after I do save the project file.
When I do scene command it not work, or just activate one group address only, can i know what happen?
Please share configuration of your scene.
(19.03.2025, 22:07)Daniel Wrote: Install Modbus profile app, you can lower it trough the app.
The download link doesn't work anymore. Could you provide the package again please?
I can't find the Modbus profile App in the store, where to find it?
https://forum.logicmachine.net/showthread.php?tid=5911
I have a FellerLynk wich has no cloud connection anymore. I'd need to update to Schneider SpaceLynk and connect to Schneider Cloud to get it up and running.
That beeing said, we only use LogicMachines now since the cloud wasn't satisfying with FellerLynk.
Long Story Short, if the Hardware is fellerLYnk(i.MX6) can i upgrade the Firmware to 2024.04 and have the benefits of a LogicMachine?
Or is there some Hardware ID "magic" that would deny access to LM-Cloud?
Thanks for your help, ypur work is highly appreceated!
Cheers
This will not work, there is hardware protection.
