Ondilo spa/pool monitor
#21
Please send your Ondilo credentials via PM.
pm done
Try this:
function getAuth()   local url = apiHost .. endpointAuth .. '?client_id=customer_api&response_type=code&redirect_uri=' .. uri .. '&scope=api&state=' .. state   local resp, code, hdrs, stat = socket.http.request(url)   local formtoken = resp:match('name="_token" value="([^"]+)">')   local cookies = hdrs['set-cookie'] or ''   local cookietoken = cookies:match('XSRF%-TOKEN=[^;]+') or ''   local cookiesession = cookies:match('interop_new_api_session=[^;]+') or ''   local escape = require('socket.url').escape   local data = {     '_token=' .. formtoken,     'email=' .. escape(usr),     'password=' .. escape(pwd),     'locale=en',     'proceed=Authorize'   }   local body = table.concat(data, '&')   local resp, code, hdrs, stat = socket.http.request({     url = url,     method = 'POST',     headers = {       ['Content-Type'] = 'application/x-www-form-urlencoded',       ['Content-Length'] = #body,       ['Referer'] = url,       ['Cookie'] = cookietoken .. '; ' .. cookiesession,     },     body = body   })   local location = hdrs.location   local auth_code = location:match('code=(%w+)')   if not auth_code then     return   end   local data = {     'code=' .. escape(auth_code),     'grant_type=authorization_code',     'client_id=customer_api',     'redirect_uri=' .. escape(uri),   }   local body = table.concat(data, '&')   local resp, code, hdrs, stat = socket.http.request({     url = apiHost .. endpointToken,     method = 'POST',     headers = {       ['Content-Type'] = 'application/x-www-form-urlencoded',       ['Content-Length'] = #body,       ['Referer'] = url,       ['Cookie'] = cookietoken .. '; ' .. cookiesession,     },     body = body   })   if code == 200 then     local data = json.decode(resp)     return data.access_token   end end
Thanks, it works again.
