Script reboot failing
I'm trying to reboot a wiser for KNX with a script.
Using this "os.execute('reboot')", the server doesn't reboot.
I also tested this "os.execute(reboot)" but i have the same result.
Respectfully,
BRUN Félix.
In General configuration there is Block unsafe functions in scripts:
Make sure to disable it.
(10.06.2024, 10:05)Daniel Wrote: In General configuration there is Block unsafe functions in scripts:
Thanks Daniel !
I have the same problem as fbrun@domizy to reboot LM5, I don't understand Daniel's answer
Jean-Marc
Utilities-> General configuration...
Thanks Daniel, it's OK
Is it also possible to reset the USB port by script, I have a Uart rs232 which from time to time blocks and I am obliged to unplug and replug
Jean-Marc
What is the device you have problem with?
It's : FTDI - FT232R USB UART
Jean-Marc
Did you check if just reboot helps? I think it will need power down anyway.
Yes reboot helps, I read the frame of a Linky electric meter every minute, some day at 8:00 a.m. the meter sends the tariff change and the ft232 blocks so either reboot or disconnect reconnect
It's not from the script!!
Jean-Marc
-- Script USB Reset Final pour LM5 OpenRB
-- Version simplifiée et optimisée
local function write_file_safe(file, value)
    local f = io.open(file, "w")
    if f then
        local success, err = pcall(function()
            f:write(value)
            f:close()
        end)
        if success then
            log("✓ Reset: " .. file)
            return true
    return false
-- Configuration LM5 validée
local USB_BUSES = {
    "/sys/devices/platform/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1",
    "/sys/devices/platform/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb2"
-- Reset USB rapide et efficace
local function restart_usb_lm5()
    log("=== Redémarrage USB LM5 ===")
    for i, bus_path in ipairs(USB_BUSES) do
        log("Reset bus USB" .. i .. "...")
        -- Désauthoriser le bus
        write_file_safe(bus_path .. "/authorized", "0")
        os.execute("sleep 1")
        -- Réauthoriser le bus
        write_file_safe(bus_path .. "/authorized", "1")
    log("✓ Reset USB terminé")
    -- Attendre la détection des périphériques
    os.execute("sleep 2")
    -- Vérification
    log("Vérification des périphériques USB...")
    local handle = io.popen("dmesg | grep -E 'ttyUSB|ftdi_sio|SerialNumber' | tail -5 2>/dev/null")
    if handle then
        for line in handle:lines() do
            log("  > " .. line)
        handle:close()
    log("=== Fin du redémarrage ===")
-- Fonction principale simplifiée
local function main(arg)
    if #arg == 0 or arg[1] == "restart" then
        restart_usb_lm5()
        log("Usage: main({\"restart\"}) ou main({})")
-- Auto-exécution
main({})
It's OK With the help of Claude.ai  Wink
Jean-Marc
You can power cycle USB port like this:
io.writefile('/dev/usbctrl', 'low')
os.sleep(1)
io.writefile('/dev/usbctrl', 'high')
os.sleep(1)
Make sure that serial port is not open in a script when doing the power cycle. Otherwise the port name might change and script won't work.
Thanks Daniel, but is not work
Jean-Marc
Is there a way from a Lua script (or system command via os.execute()) to completely cut and restore the 5V power supply to a USB port on the LM5?
Jean-Marc
Could be “block unsafe scripts” in general configuration io.writefile could be blocked, not sure if that is also on LM..
(Yesterday, 12:42)Erwin van der Zwart Wrote: Could be “block unsafe scripts” in general configuration io.writefile could be blocked, not sure if that is also on LM..
No it's not.
